Running lights not working
Old May 25, 2024 | 01:48 PM
carson g's Avatar
carson g
5th Gear
Default Running lights not working
Hey all, recently my running lights (side markers, rear lights, halos on my knight drive headlights, and interior lights) stoped working. When I put the headlight switch all the way on for low beams the low beams come on but no other lights do like they are supposed to. After about 10-15 min all of the lights finally come on and I can’t figure out why it’s doing this. Any ideas? Thanks!
Old May 26, 2024 | 12:29 AM
Moved to C5 Tech.
Old May 26, 2024 | 12:40 AM
_zebra's Avatar
_zebra
i was going to suggest checking fuses... but you say they eventually come on like they're supposed to, huh?
did the wiring for them aftermarket headlights get botched (possibly shorting, grounding out, or having an intermittent break somewhere)? also look up all the electrical ground locations to verify all are clean & making solid, tight contact.
Old May 26, 2024 | 08:07 AM
TonyCorvette_'s Avatar
TonyCorvette_
That is a common issue. The parking light contact in the MFS weakens over time.
To Running lights not working
