Golden Rod
Old Jun 1, 2024 | 11:37 AM
MuskokaRider's Avatar
MuskokaRider
Default Golden Rod
hello folks.. was adjusting vertical adj on 02 headlights.. little too high, adjusted right side down to where needs to be,
but, the rod twisted off on the left side, I have the cover off and see the adjustment in, so i need to take out the headlight I m thinking and get at the adjuster.. is there a way to adjust it with out taking it out ? and can the rod be replaced or need to replace whole adjuster ? I have read many threads on it, and does not look promising...
Any thoughts or ideas appreciated..
TIA..
Old Jun 1, 2024 | 12:37 PM
41bigdawg's Avatar
41bigdawg
I had the same issue, I just replaced the whole adjuster. Its not a difficult job just a little tedious.
Old Jun 1, 2024 | 12:41 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
The rod can be replaced but I have no experience with it yet. So I'm not sure if you can adjust the light without replacing it or taking the light out. You will have to remove it to replace the rod I'm sure though.
Here's a link to the new rod..
https://rodneydickman.com/product_in...roducts_id=497
Old Jun 1, 2024 | 12:42 PM
MuskokaRider
Yes.. thats what i was planning on.. the Stealership can t get them. where did you find, if u don t mind me asking.
Old Jun 1, 2024 | 01:17 PM
MuskokaRider
I looked at that before.. seems like is just the rod, and lot of drilling and finessing.Rather just buy the complete adjuster.
i see them on Fleabay and a few site.
Thank you
Old Jun 1, 2024 | 05:29 PM
41bigdawg's Avatar
41bigdawg
I found one on Ebay at factoryoemparts2. Mine was the vertical adjustment, worked great and I paid about $40 for it. Hope that helps
Old Jun 1, 2024 | 06:02 PM
MuskokaRider
Sure does, i saw them on that site also.. was thinking of ordering from there.. $50 + the shipping i think.. so for me to get it here is about $70 + shipping.. damn exchange rate is brutal these days.. unless the ship free to Niagara Falls Ny. Will check into it..
thanks very much BD
Old Jun 3, 2024 | 12:03 AM
Moved to C5 Tech.
Old Jun 3, 2024 | 11:27 AM
hyperv6's Avatar
hyperv6
I must be lucky mine worked perfect when I adjusted them. I even lubed them up to keep them that way,.
Old Jun 4, 2024 | 08:01 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Sorry to see that Rodney Dickman is closing up his shop. He's helped out a lot of Corvette owners, over the years, with the parts/kits that he's made....
Old Jun 4, 2024 | 08:21 AM
hyperv6's Avatar
hyperv6
Rodney was a great benefit for the Fiero Community too. I help test some parts he prototyped. He did great work and tested his products.
I used his headlight kits to save my Fiero motors. You can't buy the motors anymore and they saved my system.
Old Jun 11, 2024 | 12:47 PM
MuskokaRider
mods can close this
Old Jun 13, 2024 | 11:59 AM
grinder11's Avatar
grinder11
Lubing them is why!! These are hardly ever used. 10 years, or more, can elapse between adjustments. I always spray some penetrating oil on mine a week or so prior to any twisting. Like everything else, use it, or lose it. Bad for any mechanical part to go unused for years at a time....
To Golden Rod
