Removing the GLOVE BOX
Old Jun 2, 2024 | 09:07 AM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
Default Removing the GLOVE BOX
Can someone please give me quick directions on how to rem9ve the blove box please?
Old Jun 2, 2024 | 06:16 PM
USAZR1's Avatar
USAZR1
Might try posting this in C5 Tech.
Old Jun 2, 2024 | 10:03 PM
jwg2's Avatar
jwg2
after opening the glove box, there are some pretty obvious bolts across the top of the box. the bolts in the bottom are tricky...on the bottom of the glove box there are two round plastic plugs. you have to pop these plugs out and there are two bolts accessible through the plug holes. the glove box is a little easier to handle if you do the bottom bolts first. there are a couple of electrical connections for the airbag key etc., unclip those and you box should come out.
Old Jun 2, 2024 | 11:44 PM
Moved to C5 Tech.
To Removing the GLOVE BOX
