Rear left squeaking
Old Jun 9, 2024 | 04:54 PM
Corvette.Mike's Avatar
Corvette.Mike
7th Gear
Default Rear left squeaking
Hi,
The video is self-explanatory lol
I've had this squeaking problem for months, I've read a lot of info on the forum about common squeaking problems.
My bilstein shocks are new (3000 miles) I recently replaced the sway bar bushings and end link. The squeaking has not disappeared. I disassembled everything, shocks and reversed with the right one, leaf spring bushings, control arms to lubricate bushings with silicone grease. The squeaking has returned. Any ideas, leaf spring?
Old Jun 10, 2024 | 10:19 PM
natchamp's Avatar
natchamp
Sounds like metal to metal. Inner or outer tie rod? Can you have someone bounce the car while you put your hand on the parts to feel the vibration of the squeak? Unhook the sway bar on that side or loosen the bracket to subframe. Or unbolt the outer tie rod and pop it out.
Old Jun 11, 2024 | 10:56 AM
DWC4's Avatar
DWC4
Default bushings
I know you said you lubricated the bushings but that’s a classic source of squeaks. Been there.
Because it’s an easy fast fix Id remove them again, wrap the metal with plumber tape, lube that area AND inside the bushings thoroughly - and reassemble.
Good luck!
Old Jun 12, 2024 | 04:41 AM
Corvette.Mike
7th Gear
I'll take a look at the tie rod, I hadn't thought of it
thanks
To Rear left squeaking
