How to Pull & Reset Codes?
Old Jun 18, 2024 | 02:14 PM
57gman's Avatar
57gman
Default How to Pull & Reset Codes?
Please.....................
Old Jun 18, 2024 | 02:35 PM
USAZR1's Avatar
USAZR1
How to Pull Codes:
1. Turn your key to the "ON" position, but do not start the engine.
2. Clear any present messages by pressing the RESET button.
3. Hold the OPTIONS button down, and press the FUEL button 4 times. (This will get you into the "codes" section of the DIC.
4. The computer will automatically display all the codes your car has created. It will cycle through each code every 3 seconds. (Have a pen and paper handy to write down the codes)
Note: Any code that ends in an "H" is a history code (something that has occurred in the past, but is not reporting as an error currently.)
5. Once the computer has finished going through all of its codes, press RESET to enter Manual Configuration mode. It should start with a module and show "NO CODES" or "# Codes."
6. To optionally reset codes once in manual mode, press and hold RESET until is displays "NO CODES."
7. Press OPTIONS to go into the next module (ie, from PCM, or Powertrain Control Module, to TCS, or Traction Control System.)
8. Repeat Step 6 until you have reset all the codes in all the computer modules.
Note: Only reset the codes if you want to- it is not necessary to reset them every time you pull the codes.
9. When finished, simply take your key out of the ignition.
Old Jun 18, 2024 | 09:14 PM
57gman's Avatar
57gman
Thank You. My security light stays on and I want to see if it goes away!
Old Jun 18, 2024 | 10:14 PM
devnull's Avatar
devnull
Scientific Negotiator
St. Jude Donor '07-'08-'10, '14
Coolest feature of these cars. I miss my C5Z!
Old Jun 19, 2024 | 10:53 PM
Moved to C5 Tech.
To How to Pull & Reset Codes?
