issue with HVAC diffusers not switching positions.
Old Jun 18, 2024 | 02:30 PM
Jayboost99's Avatar
Jayboost99
4th Gear
Default issue with HVAC diffusers not switching positions.
Hello All!. I have a 99 and the issue is the vents don’t switch positions. The Control works fine. When I run heat or A/C the air seeps out from every vent just a little bit and it isn’t efficient at heating or cooling. The car has no HVAC codes in the onboard diagnostic but it does have an air air system codeP0410 and also P1416 Air system bank 2. Anyone ever have a similar issue with their C5? Thanks
Old Jun 18, 2024 | 04:30 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
The vent actuators are vacuum operated. There is a vacuum line that powers the actuator control that runs from the rear of the intake manifold under the battery to an HVAC vacuum system reservoir and to the the HVAC actuator control located in the passenger footwell through the passenger side bulkhead. Its a common defect; you will have to replace or repair the damaged vacuum line. You will find many posts on this subject, I recommend you use the search function.
Old Jun 18, 2024 | 04:51 PM
bookyoh's Avatar
bookyoh
As ipuig wrote, there are any threads on this issue. In the last one or two months, a Forum member went down an excellent diagnostic path, with photos, to solve his issue. His problem seemed to be much rarer. He had a good vacuum source and good vacuum through the lines. In his case, it was a solenoid which opens and closes vacuum to the actuator.
Sorry that I don’t recall who the Forum member was but a search of C5 Tech will find it.
Found the thread: https://www.corvetteforum.com/forums...readid=4833273
Old Jun 19, 2024 | 08:21 AM
Jayboost99's Avatar
Jayboost99
4th Gear
Thanks for the good info! I’m going to start checking all the vacuum lines.
Old Jun 19, 2024 | 08:54 AM
grinder11's Avatar
grinder11
Many threads on this common issue. Sadly, the C5 mixes both electronics and vaccum in the HVAC system. Hence there is some confusion. Not disputing the other posts, just trying to provide some clear info. Air temperature controls are usually the electronic air actuators/air dams. As in one side is hot while the other is icy cold when controls are set to cold or hot. Distribution is usually vacuum. As in having the dash vents selected, but air comes out at the foot level vents, or the defrost vents. Also, some codes only show while the engine is running. Hope this helps...
Old Jun 19, 2024 | 03:41 PM
yellow2007's Avatar
yellow2007
I had this issue several months ago. Ended up being a vacuum leak in the line behind the passengers wheel well.
Old Jun 24, 2024 | 12:10 PM
Jayboost99's Avatar
Jayboost99
4th Gear
This is what mine looks like. I thought I’d see an extra 90 going somewhere else.
Old Jun 24, 2024 | 12:27 PM
Jayboost99's Avatar
Jayboost99
4th Gear
Here it is
This is mine. Anyone know why there isn’t more branch fittings on here. The car has an AIR injection system. Thanks again!
To issue with HVAC diffusers not switching positions.
