Please explain wheel offset
Old Jun 22, 2024 | 04:29 PM
stvaughn's Avatar
stvaughn
St. Jude Donor '15
Default Please explain wheel offset
What’s the relationship between the wheel offset and how the tire lines up with the fender?
Old Jun 22, 2024 | 06:27 PM
USAZR1's Avatar
USAZR1
More offset moves the tire inboard. Less moves it out.
Old Jun 22, 2024 | 08:23 PM
stvaughn's Avatar
stvaughn
St. Jude Donor '15
Old Jun 22, 2024 | 08:47 PM
sonicss33's Avatar
sonicss33
Great explanation. Brief and to the point
Old Jun 22, 2024 | 09:39 PM
stvaughn's Avatar
stvaughn
St. Jude Donor '15
How is the offset actually measured?
Old Jun 22, 2024 | 10:30 PM
jamieo's Avatar
jamieo
From the centerline of the wheel.
Old Jun 22, 2024 | 10:44 PM
stvaughn's Avatar
stvaughn
St. Jude Donor '15
To what point?
Old Jun 22, 2024 | 11:16 PM
USAZR1's Avatar
USAZR1
[QUOTE=stvaughn;1607923336]How is the offset actually measured?[
/QUOTE]
Let's say we have a 19x11 wheel. Wheel width is measured from tire bead to tire bead. However, a wheel that's advertised as an 11" width is actually 12" wide, outside edge to outside edge. With me, so far?
Now, 12.0" divided in half = 6.0". Measure the wheel's backspacing. Let's say that number is 6". Offset on that wheel would be 0mm. (backspace is measured in inches, offset in millimeters)
If I haven't lost you yet, I had my 19x11 rear wheels built to my specs so I could fit a 325 tire under the car. Offset on them is +65. We know that zero offset on that width wheel is 6.0" so convert 65mm to inches = 2.56".
6.0" + 2.56" = 8.56. That means my 19x11 wheels w/+65 offset have 8.56" of backspacing. If you don't know what your wheel offset or width is, you can use this process to figure it out.
I know this sounds confusing, at first, but one you know the basic fundamentals, it all becomes clear.
Old Jun 23, 2024 | 08:16 AM
stvaughn's Avatar
stvaughn
St. Jude Donor '15
[QUOTE=USAZR1;1607923545]
/QUOTE]
My Z has a spacer installed by the PO on the rear wheel so that effectively reduces the offset by the thickness of the spacer, correct?
Old Jun 23, 2024 | 09:07 AM
jamieo's Avatar
jamieo
That is correct.Confused yet??
Old Jun 23, 2024 | 08:30 PM
USAZR1's Avatar
USAZR1
[QUOTE=stvaughn;1607923994 My Z has a spacer installed by the PO on the rear wheel so that effectively reduces the offset by the thickness of the spacer, correct?
[/QUOTE]
To better understand, imagine that spacer was attached to the wheel hub. That would reduce the positive backspacing, correct? Less backspace = less offset
To Please explain wheel offset
