C5 2003 problem start motor
Old Jul 2, 2024 | 02:39 PM
kh400's Avatar
kh400
Originally Posted by Mauri_C5
Ok thanks! i ll try to do it.
The battery is new. replaced 2 weeks ago.
Remove the B+ wire from the starter. Clean, really clean the wire terminal with some emory cloth till the copper shines. Also, clean the starter terminal stud and surrounding area. This connection builds up high resistance, probably due to the heat. Anyway, your alternator feed(B+) goes through this terminal before it reaches the battery. So, you get reduced charging voltage and high resistance when you crank. Common problem. On mine, I also ran a separate #6 guage wire from the alt B+ directly to the pos batt terminal along with a 250 amp fuse link (available at Advance) Hope this helps
Old Jul 3, 2024 | 03:54 AM
Mauri_C5's Avatar
Mauri_C5
Last year before to change the start motor, yes, the start motor ran more slowely. When i replaced it, it ran very fast.
