I was gifted 18” rims and wanted to know if a 255/40/18 in the front will work with the existing original tire size 275/40/18? Once I wear out the rear tires I will go to my preferred sizes 275/35/18 front and 295/35/18 rear ……. Just short on cash and also the rear tires are only a year old …. Any information will be greatly appreciated 👍🇺🇸
I'm here to tell you that this must vary from car to car, or it is simply not true. I dont know which, but I do know that I ran Michelin 315-30-18 PS2s on the rear for many years, while running the stock 245-45-17s on the front. The rears measured just 25.44" diameter, while the fronts were slightly LARGER at 25.68"! I never had any AH/TC issues. Even when reducing the air pressure in the rears to 16lbs-20lbs looking for some extra traction at the strip, which would've made the rears even smaller. I also put 40lbs in the front tires to try for reduced rolling resistance, which would've made them slightly larger. My experiences, YMMV......
First off, the AH/TC system on C5's is not sensitive, at all. Lots of people are running square set-ups, without issues. Your experience doesn't surprise me because the diameter differences are so small but my first C5 didn't even like a square set-up.
Strangely enough, these cars don't seem to care when the rear tires are substantially larger.
