Tapping DRL signal for pulse
Old Jul 2, 2024 | 02:13 PM
Beaucarney's Avatar
Beaucarney
Navigator
Default Tapping DRL signal for pulse
I am trying to tap the drl/turn signal circuit for my push button start. The push button module gets a signal from the door lock, along with the pulse from the lights when locking/unlocking to activate/deactivate power to the button.
I originally tapped into the lights on the climate control, which works for unlocking but not locking.
I tapped the wire from the light switch in the car, but it doesn’t get power from the remote.
is there somewhere at the BCM inside the car I can tap, that the BCM sends signal to the lights when locking with the remote?
Old Jul 2, 2024 | 10:48 PM
chain_5001's Avatar
chain_5001
I used the door lock/unlock wires on the bcm in the driver's door. Does you system not use a proximity sensor to activate/deactivate the start button?
Old Jul 2, 2024 | 11:14 PM
Beaucarney's Avatar
Beaucarney
Navigator
yeah, I used the same but my system also uses a pulse from the factory alarm when disabling. Instructions state to tap the turn signal or running light. I guess so just unlocking the door does not activate the switch, has to have the lock/unlock pulse plus a pulse that the alarm is activate/deactivated.
Old Jul 2, 2024 | 11:18 PM
chain_5001's Avatar
chain_5001
I've heard the alarm arm/disarm wires are in the driver's kick panel. I've never located them myself.
To Tapping DRL signal for pulse
