Alignment Spec Conversion
Old Feb 2, 2003 | 12:29 AM
Bandit1's Avatar
Bandit1
Default Alignment Spec Conversion
Does anyone know what the conversion is from inches to degrees on alignments on OEM wheels and tires for 1/16" and 1/32" toe in? I'm not convinced my alignment tech is using the right conversion chart.
:skep:
Old Feb 2, 2003 | 02:58 AM
C5stein's Avatar
0C5stein
Former Vendor
Default Re: Alignment Spec Conversion (Bandit1)
Bandit,
According to my alignment machine:
1/8" = 1/4 degree
I hope this helps.
Old Feb 2, 2003 | 11:47 AM
Bandit1's Avatar
Bandit1
Default Re: Alignment Spec Conversion (C5stein)
So, if I want a 1/32" toe-in on the front, and 1/16" toe-in on the rear, what should the degree read out look like on the computer printout? :confused:
Old Feb 2, 2003 | 12:48 PM
MTWallet's Avatar
MTWallet
Is this what you you want?
1" = 4.775 degrees
1/2" (.500") = 2.387 degrees
1/4" (.250") = 1.193 degrees
1/8" (.125") = .596 degrees
1/16" (.0625") = .298 degrees
1/32 (.0312") = .149 degrees
1/64 (.0156") = .0746 degrees
etc., etc., etc.,
Old Feb 9, 2003 | 01:54 AM
Bandit1's Avatar
Bandit1
Default Re: Alignment Spec Conversion (MTWallet)
Thats exactly it. Thanks for the info. :seeya
Old Feb 9, 2003 | 01:55 AM
Bandit1's Avatar
Bandit1
C5Stein--Thanks for the conversion info. :hurray:
Old Feb 9, 2003 | 02:16 PM
MTWallet's Avatar
MTWallet
I believe C5Steins conversion is not correct or he misread it. Mine is direct from a dimensional engineering reference that I use everyday. Anyone else care to verify the info for Bandit1 or is the subject dead?
[Modified by MTWallet, 1:16 PM 2/9/2003]
To Alignment Spec Conversion
