Key FOB issue
Old Jul 14, 2024 | 01:48 AM
Hotrodzz3's Avatar
Hotrodzz3
Default Key FOB issue
I just got home from a 7,000 mile road trip in my C5 and am having some issues with my FOB's. On the trip I had issues with water as I went thru some heavy rains and the car did leak water into the cabin although not a lot. The car runs fine and is throwing the following codes BO-RFA U1096H, BO-RFA U1064H, and BO-RFA U1016H. All functions of the FOB's seem to be working fine except that the car is locking and unlocking on it's own and the remotes won't stay synced to the car, seems to be doing it with both fobs. I have re-trained the fob's thru the DIC and no change in the problem. I also changed batteries in both of them. Car is a 99 and does have passive on the fobs although passive is turned off on both fob's. I have never had any problem with them until I got caught in the heavy rains on this trip. Any ideas or help in figuring this out would be appreciated
Old Jul 14, 2024 | 10:22 AM
Joe Scafide's Avatar
Joe Scafide
Default Fobs
Try disconnect the batttery
Old Jul 14, 2024 | 10:53 AM
yellow2007's Avatar
yellow2007
Old Jul 14, 2024 | 04:22 PM
Hotrodzz3's Avatar
Hotrodzz3
I will try that later today and let everyone know if that helps
Bob
Old Jul 15, 2024 | 01:41 AM
Hotrodzz3's Avatar
Hotrodzz3
I tried disconnecting the battery today for an hour then reconnected the battery, then retrained the FOB;s thru the DIC and the car still unlocks itself when I walk into the garage with either FOB. When I retrained them I also changed the setting under options for passive to unlock only the drivers door and now that is the only door that unlocks itself. Is there a way to turn passive off completely other that the switch on the FOB's, I have them both set to off.
To Key FOB issue
