Memory Pkg - Crazy Driver Side Mirror
Old Jul 17, 2024 | 12:32 AM
Gmanh's Avatar
Gmanh
Default Memory Pkg - Crazy Driver Side Mirror
02' C5 with memory package. When I unlock the door with key fob the driver side mirror goes into an adjustment mode that moves it all over the place. It eventually stops in a position that is no where close to where it was set. It's been set a million times in Mem #1 position but goes nuts when I use the fob to get in the car. Seat does not re-adjust passenger mirror does not re-adjust. Just driver mirror. Sick of using my key unlock the car. Anyone been through this?
Thanks to all
Glenn in San Diego
Old Jul 17, 2024 | 10:26 AM
jdmvette's Avatar
jdmvette
Night Owl for life
This is a common "feature" on the C5.
Set it where you want it and unplug it from the wire harness behind the door panel... Problem solved.
Old Jul 17, 2024 | 10:27 AM
JCMDoug's Avatar
JCMDoug
I have the same thing, and just used my new OTOFIX scan tool on it. (thanks to Toys4Life doing a video using it)
What I got back was a loss of feedback communication from the mirror so it has no clue what the position is and just goes nuts.
​​​​​​It's been crazy hot so when it cools down I am going to dig into it, could just be a wire or bad module. Thanks to the OTOFIX I have a direction to start my hunt for the issue.
Old Jul 17, 2024 | 03:01 PM
rrwirsi's Avatar
rrwirsi
Just another electrical anomaly I have learned to work around in my '04. My mirrors will do a 'jig' when I use the key fab to open the car. The owners manual says that the memory recall can be stopped by pressing one of the mirror buttons. Not so in my 04. Now, I just use the key to open the door if I do not want the mirrors to do the 'jig'.
Old Jul 17, 2024 | 03:44 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
My mirrors do the same thing, I have just learned to live with it.
Old Jul 17, 2024 | 08:59 PM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
Yep mine also do this. Annoying. lol
Old Jul 17, 2024 | 10:17 PM
Gmanh's Avatar
Gmanh
Wow no one has beat this???? Pisses me off every time I get in the car. Been using the key for 10 yrs!
Old Jul 18, 2024 | 12:09 AM
Choreo's Avatar
Choreo
My 2001 started doing that right after I bought it (new) and they replaced both my mirror motor packs under warranty. A few months later, started again. In my case, it seems like the mirror pegs seem to become somewhat loose in their sockets (there are two motor drive pegs and I am guessing the other two pegs are for position feedback?). I have found when the mirrors really act up, sometimes if I grab the mirror and housing with both hands and squeeze them together things start working again for a while?
On the plus side, after living with it for 24 years, my eyes now move independently.
Old Jul 18, 2024 | 02:10 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Post 2
Old Jul 20, 2024 | 01:50 PM
TheBac's Avatar
TheBac
Using the scan tool on the instrument cluster, are you guys getting comm codes concerning the drivers door module when this happens?
Old Jul 20, 2024 | 08:10 PM
Gmanh's Avatar
Gmanh
Yeah my glass flutters a little when bass in door speaker is up. A little sloppy when adjusting also. Scared to death to put a lot of pressure on the glass in the event one of pegs is not in. Videos of using a block of wood with a towel to spread the pressure but **** that's an expensive piece of glass (dim feature).
Old Jul 25, 2024 | 02:40 PM
3sACROWD's Avatar
3sACROWD
Mine is doing the same thing but I replaced the glass just before this all started. I have to go back and look at the pegs.
Old Jul 30, 2024 | 11:14 AM
Moving this to C5 Tech for more suggestions on how to fix the mirror problem.
To Memory Pkg - Crazy Driver Side Mirror
