C5 hi performance water pump
Old Jul 17, 2024 | 12:02 PM
Bwadd's Avatar
Bwadd
Default C5 hi performance water pump
Looking for experiences with hi flow or hi performance mechanical water pumps. 2004 LS6 Z06.
Thanks.
Old Jul 17, 2024 | 06:27 PM
JDiv48's Avatar
JDiv48
Stick with a stock GM pump. Flow rate is a science for proper cooling.
Old Jul 17, 2024 | 07:56 PM
Bwadd's Avatar
Bwadd
Default Stock pump
I'd like to find an American made pump....pretty sure Gates and AC Delco are imports.
Edelbrock and Evans are US products I believe.
Old Jul 17, 2024 | 10:07 PM
vette4fl's Avatar
vette4fl
The faster the flow, the greater the efficiency. That’s science.
Old school used to be not to move the coolant through the radiator too fast, so it has time to cool. Problem with that is the rest of the water is in the engine longer getting hotter. Frankly, I’d just get a better radiator.
Check these out:
https://www.summitracing.com/search/...0water%20pumps
Old Jul 17, 2024 | 10:29 PM
Smoken1's Avatar
Smoken1
I've been running the PRW pump and never had a problem with the car overheating
Old Jul 18, 2024 | 04:54 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
Thanks.
The OEM spec. water pumps are more than adequate.
To C5 hi performance water pump
