Eyewinn
Old Jul 23, 2024 | 04:47 PM
Eyewinn's Avatar
Eyewinn
4th Gear
Default Eyewinn
2002 Convertible. Has anyone experienced issues after removing battery, reinstalling the battery? Drivers side headlight will not stay down. The car only has 26k miles so I don’t believe it’s a mechanical issue. As soon as I reconnected battery the light flipped up. I drove the car for 20 minutes to allow the computer to relearn. Do I have a dumb Corvette?😂😂
Old Jul 24, 2024 | 08:50 AM
Fast one's Avatar
Fast one
Did you lower the light using the **** on the motor?
Old Jul 24, 2024 | 09:19 AM
rrwirsi's Avatar
rrwirsi
Thoughts: 1) Make sure all the bump stops are attached; 2) Disconnect the wiring between the headlight motor and control module and make sure the connections are clean and fit tightly.
Old Jul 24, 2024 | 09:24 AM
Eyewinn's Avatar
Eyewinn
4th Gear
thank you
Old Jul 24, 2024 | 09:25 AM
Eyewinn's Avatar
Eyewinn
4th Gear
Thanks. I will check
To Eyewinn
