Clutch didn't return to engaged position
Old Jul 26, 2024 | 07:51 PM
B-STOCK's Avatar
B-STOCK
St. Jude Donor '14-'15, '17, '19
Default Clutch didn't return to engaged position
Wife and I took a ride to the Cape today. Hot day, one & 1/2 hours of highway driving with the top down and AC on. The last 10 miles were stop and go almost gridlock. Stopped for lunch and after 2 hours returned to car to restart and my foot couldn't find the clutch petal. Dah. ,The clutch petal was all the way to the floor. knelt down and manually lifted it up and things were fine all the way home. any ideas, 2000 M6 vert with 35 K on it. Any idea what happened. I know it's time to change the fluids, could this attribute to it. Thanks a lot. Mike
Old Jul 26, 2024 | 11:45 PM
bookyoh's Avatar
bookyoh
There are quite a few threads on clutch pedal that does not return. Most of them seem to be the clutch slave cylinder and/or clutch master cylinder. Flushing the clutch fluid if you have a remote bleeder or using the Ranger method if you do not is usually suggested and checking that the return spring is in place as well.
Old Jul 26, 2024 | 11:49 PM
B-STOCK's Avatar
B-STOCK
Where is the return spring
Old Jul 27, 2024 | 02:24 AM
Moved to C5 Tech.
Old Jul 27, 2024 | 12:10 PM
mmartinez's Avatar
mmartinez
On the pedal under the dash
To Clutch didn't return to engaged position
