Blower Motor Volumn
Old Jul 28, 2024 | 01:55 PM
d.moscatelli@comcast's Avatar
Default Blower Motor Volumn
Sorry if this is redundent.
I have owner my 1998 C5 for 18 months. Since I have owned it the volumn of air coming from the vents has been low at best, even when the blower motor speed is set to it's highest output. I found the vacuum line at the back of the intake manifold was disconnected. I connected it and that help a bunch. Now when the blower is set on max, I get air blower volumn about medium, but still not full. My son has an 2001 C5 , and his air volumn at high speed is at least twice what mine is now.
When I purchased the car , the next day I replaced both of the blend door actuators. That fixed where the air was being distributed ( defrost, dash, foot well ) problem, but not the low volumn of air. As mentioned above, when I connected the vacuum hose to the back of the intake manifold, that helped a bunch, but not like my sons on his 2001.
So I'm thinking there might still be a vacuum leak, but am not sure. Oh, I forgot to mention, I have replaced the blower motor.
Any thoughts???
Old Jul 28, 2024 | 02:21 PM
rrwirsi's Avatar
rrwirsi
Thoughts. Maybe there is a blockage somewhere. When I had air flow problems and before doing any replacing, I vacumed the system out from both sides and front. I found stuff in the vacume bag that appears to have been causing the problem.
Old Jul 28, 2024 | 05:58 PM
bookyoh's Avatar
bookyoh
A simple way to check if the mode door is changing modes fully:
Set the mode to Vent
Blower on high
check and feel the floor and defrost outlets, do you feel any air?
Set to floor and do the same feel test for vent and defrost
Set to defrost and do the same feel test for vent and floor
If you feel air flow in modes where you should not, you have a mode actuator problem, mode door problem, or vacuum problem.
Old Jul 28, 2024 | 08:32 PM
redzg's Avatar
redzg
Recirculate will always flow more air than fresh. I notice on my ‘99 that max speed varies considerably more than I would expect, and wonder if it isn’t due to the control panel.
Old Jul 30, 2024 | 08:39 AM
Moved to C5 Tech for further comment.
Old Jul 30, 2024 | 09:21 AM
lucky131969's Avatar
lucky131969
Any thoughts???
What is your measured engine vacuum at idle?
Old Jul 30, 2024 | 02:46 PM
jim993's Avatar
jim993
Have you checked the blower wheel to see if there is a mouse nest in there?
Old Jul 31, 2024 | 10:21 AM
Markmbaha1's Avatar
Markmbaha1
Any thoughts???
I got in mine last weekend and saw something by my right foot. It was a piece of real thin dark gray foam like material I've seen in and around the vents and connections to outlets...So it either fell out or was blown out through the heat ducts. Could be a piece of that stuff that has started to crumble and or disintegrate over all these years, has broken free and blown around partky blocking a vent. I just remembered I had a piece of the same stuff that had blown up against the far left driver's AC vent.
To Blower Motor Volumn
