2001 C5 Z06 help!
Old Jul 28, 2024 | 04:25 PM
NateC5Z06's Avatar
NateC5Z06
3rd Gear
Default 2001 C5 Z06 help!
I recently purchased a 2001 C5 Z06 from a guy in Texas that has a leak at the trans/diff seal. Trans and diff fluid is leaking onto the rear leaf spring, although it is mostly trans fluid. I’ve found conflicting information on what the fix entails and I’m looking for some advice. As far a I understand I should just need to replace the inner and outer output shaft seal for the trans side and some Orings for where the diff mounts to the extension housing. Is this all I would need to fix likely? If so
does anyone know the specific part numbers?
Old Jul 28, 2024 | 08:24 PM
kkupec02's Avatar
kkupec02
No, but Welcome
Old Jul 28, 2024 | 09:26 PM
Moved to C5 Tech for some help. And welcome to the forum.
Old Jul 29, 2024 | 11:24 AM
CinciZ06's Avatar
CinciZ06
You are on the right track with the seals. As far as part numbers, your easiest answer is to go to www.rockauto.com and navigate to the manual transmission section for your car and all of the seals are right there to choose from with various manufacturers.
To 2001 C5 Z06 help!
