P0332 and p0327
Old Jul 31, 2024 | 03:41 PM
neansord's Avatar
neansord
3rd Gear
Default P0332 and p0327
Hello all, I'm having both of these codes, p0332 and p0327, which I know mean the knock sensors. They came on and the same time, so I have a feeling replacing them isn't going to fix it. What should I try first? I have no clue where to start since it's probably electrical. Thank you everybody in advance for any and all advice.👍
Old Jul 31, 2024 | 08:28 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Old Jul 31, 2024 | 08:32 PM
C5 Diag's Avatar
C5 Diag
Old Jul 31, 2024 | 09:42 PM
neansord's Avatar
neansord
3rd Gear
Does this also apply since both of those codes have tripped? sorry...
Old Aug 1, 2024 | 12:01 AM
C5 Diag's Avatar
C5 Diag
I couldn’t tell you if both DTC’s set at the same time as you mentioned but you will have to follow the diagnostic “tree” if you want to…electrical schematic below…always helps if we at least know your model year…some things are different with these cars in different platform years…if replacing the sensors torquing them to 15 ft lbs is important.
Old Aug 1, 2024 | 10:09 AM
neansord's Avatar
neansord
3rd Gear
my apologies, it's a 2000 convertible with about 131,000 miles on it.
Old Aug 1, 2024 | 10:13 AM
C5 Diag's Avatar
C5 Diag
Wiring diagram is for a 2000 so should be the same….good luck !!
To P0332 and p0327
