A4 Shifting Problem
Old Aug 4, 2024 | 04:09 PM
jcj63's Avatar
jcj63
Default A4 Shifting Problem
Helping a friend. 2002 base coupe A4. No mods other than CAI. Trans will not upshift until we let off gas. Downshifts fine. Doesn't matter what speed or RPM. No trans specific codes. Do have the following communication codes.
Left Door U1016 Loss of Communications with PCM
U1064 Loss of Communications with BCM
Right Door U1016 Loss of Communications with PCM
U1096 Loss of Communications with IPC
U1255 Serial Data Line Malfunction
Seat SCM U1016 Loss of Communications with PCM
There are other codes specific to each of those areas and TCS/ABS is bad. I did read that a bad TPS could cause the same symptoms but the voltages are all in line. Thanks for any ideas.
Old Aug 5, 2024 | 12:11 AM
jim993's Avatar
jim993
First, check the transmission fluid level.
To do so, the car has to be raised. Fluid level is checked with the engine running, transmission in park after shifting through the gears. With the transmission temperature at 122 F on the DIC.
Do NOT remove the fill/ level check plug UNLESS the engine is running, transmission in park. Install the plug BEFORE shutting down the engine. If you shut down the engine with the fill/level check plug not installed, fluid will pour out and the transmission will be low on fluid.
Old Aug 5, 2024 | 09:52 AM
jcj63's Avatar
jcj63
Forgot to say we checked the fluid level. Also no slippage in any gear.
Old Aug 5, 2024 | 07:00 PM
grinder11's Avatar
grinder11
Has the car been tuned?
Old Aug 6, 2024 | 08:34 AM
cdee63's Avatar
cdee63
2024 C5of the Year Finalist - Unmodified
No expert, but could the problem have anything to do with the several communication issues?
Old Aug 6, 2024 | 09:41 AM
jcj63's Avatar
jcj63
No tune. Engine is stock except for cold air intake.
Old Aug 6, 2024 | 09:42 AM
jcj63's Avatar
jcj63
That is part of my question. I also don't know enough about all the electronics on these cars.
Old Aug 6, 2024 | 03:41 PM
Beast's Avatar
Beast
So, if you hold the throttle to the floor, engine bounces off the rev limiter in every gear, just doesn’t up shift?
Old Aug 6, 2024 | 04:24 PM
jcj63's Avatar
jcj63
That's true but also true at slow speeds.
Old Aug 8, 2024 | 09:45 AM
jcj63's Avatar
jcj63
Any other thoughts?
To A4 Shifting Problem
