Codes everywhere and a simple solution.....
Problem continued for a couple weeks, then on my way to work one morning, all hell broke loose. Cluster lit up like a Christmas tree, many messages on the DIC.
When I checked codes (yep, shoulda done that first thing), EVERY module in the car had something, except the driver's door module, which listed as "No Comm". A-ha!
Reading a couple threads on here, C5Diag and Bill Curlee both said that the issue was in the connectors to the drivers door module within the accordian between the door and body. They posited that either a wire had gotten worn through, or the female part of the power/ground connectors needed to be checked for connection. In my case, it turned out to be the latter, which I fixed by using a small pick on the female pins to close them up.
Buttoned up the car, went back into the diagnostics tool in the car, cleared all codes and checked again. The drivers door module was now reporting in, and every module reported back as clear. Been a week, and still no codes. Gotta like a simple fix like that.
Thanks, C5Diag and Bill!
