2003 c5 z06
Old Aug 13, 2024 | 04:38 PM
Forex618's Avatar
Forex618
7th Gear
Default 2003 c5 z06
Hello, I am a new member for the forum. I have been looking for a Corvette for five years. i finally found one in August 2023.It had 88 K miles on with a mild cam and MP1200 supercharger. I paid 24.5 cash for it as a retirement gift to myself and I had planned on using it as a track car at Thunderhill in California. The car ran great for 8 months and is an absolute joy to drive in every way. About 4 months ago it started to not start intermittently, turn it off and try to restart with nothing, just flat line, wait ten minutes and then starts right up. Eventually it would not start at all. Since I bought it, it has thrown active handling codes and HVAC codes. I had it aligned by a former Corvette race driver and the active handling errors stopped. I paid a mobile mechanic to install a new ignition switch, and both actuators, and once installed the car would not start. But said pull key after 10 seconds. So, he found a brown wire at the BCM that was disconnected, fixed that and reinstalled the old switch and the car started perfectly. However, the fob and alarm system would not work, apparently, he damaged the connection, so I took it to an alarm shop, and they got the fob and alarm working again. Also, the AC will turn on and then go off within a few seconds, it blows very hot air and fuse 24 blows immediately. A week goes by and now the car will not start again. I hired another mobile mechanic, he found a resistor patched into the BCM, that was put in very bad, so he soldered two new resistors into and crimped the wires. He put in the old switch again and it starts right up, but is throwing codes P0645, P1546. i pulled the ac clutch relay and ordered a new one. After I reinstalled the old one, the car just cranks and will not start. It is now throwing codes RFA, SDM, TCS U1000, BCM B2527, U1255,SDM U1016, PCM no communication, Low fuel, reduced engine power, active handling. I have spent over $ 1500.00 dollars in parts and mobile mechanics over the last few weeks, and nobody can figure this thing out. I am extremely frustrated with this situation and am on the verge of letting the car go with a huge loss. It seems like a bottomless pit of never-ending repairs. I do not have the ability to fix this myself, but I was wondering if anybody here can recommend a Corvette specialist in the Sacramento Ca. area. As many good mechanics will not work on these cars and the ones who do cannot correctly diagnose the situation. I am scheduled to tow it to the Dealership next week, but I know what that is going to cost. And I have a supercharged Dodge Challenger in the shop with a 7 K plus repair bill at the same time. I am getting destroyed by these two cars financially. Any help would be appreciated. Thank you.
Old Aug 13, 2024 | 07:24 PM
Welcome and moving this thread to the C5 Tech section for some advice.
Old Aug 13, 2024 | 07:33 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Don't take the car to a dealership because they are clueless and will only change more parts...find an auto electric shop in your area and take it there...your Corvette does not have a magical electrical system that only Corvette shops or dealerships can diagnose !!...if you have a no comm with the PCM the car won't start.
Old Aug 13, 2024 | 08:31 PM
kkupec02's Avatar
kkupec02
Welcome
Old Aug 15, 2024 | 11:15 PM
Forex618's Avatar
Forex618
7th Gear
Okay, thanks C5 Diagnosis. I checked a local car electrician. but was also recommended by a place called TBR Garage in Sacramento to go to a place called LS PROS. It is run by two guys who were former GM mechanics for twenty years. They seem to be like Corvette engineers pretty much, so I will go with that shop and see what happens;
To 2003 c5 z06
