Advice Needed: Additional Maintenance While Rebuilding Torque Tube
Could anyone share current best practices for this type of maintenance? Specifically, are there any other components or parts I should consider replacing while the torque tube is being rebuilt? Also, I would appreciate recommendations for reliable sources or brands for these parts.
Thanks in advance for your help and advice!
https://www.txdrivetrain.com/product...d-bearing-kit/
Rock auto has the GM couplers at $141 each -- the German BMW version may be as good for less, but too much risk for my money.
https://www.rockauto.com/en/catalog/...ex+joint,10701
C5 (1997–2004) New Parts Corvette Parts Center
The rear main seal is a very good idea -- in that same vein, a remote bleeder is an absolute "must", if you don't already have one. This is the first time I've heard of re-balancing the tube on a rebuild, though there have been reports of people losing the assembly orientation, which could definitely have an effect. Generally, it's a matter of match marking the input and output shafts to center shaft, so that the orientation remains the same.
I would think it possible to assemble the center shaft and have it balanced in a manner very similar to a normal drive shaft prior to final assembly in the outer tube. Might take a trip to a drive shaft balance shop to find out. It's also important to make sure the couplers face the correct way -- there are arrows molded into the rubber, though I fear I have forgotten which way the arrows face!
I used their couplers and I still know the guy that bought that car. No issues.
The TT rebuild is pretty straightforward, but I used a local well respected driveline shop to balance everything. It’s cheap insurance IMO vs just aligning the bolts all back in the holes the came from.
