Clutch fluid change & problem HELP
Old Aug 25, 2024 | 01:39 PM
B-STOCK's Avatar
B-STOCK
St. Jude Donor '14-'15, '17, '19
Default Clutch fluid change & problem HELP
2000 Vert. Had the fluids changed at the dealer and picked it up yesterday. When I started the car Saturday the clutch petal was at the floor. Tried to lift the petal with my foot and noticed I had fluid stains on my suede shoes. Pulled the petal up by hand and had some fluid on my fingers. Just a good drop om my finger and a film on the palm of my hand when wiping the clutch arm with my hand. No stain on the floor or mat. This dealer does great work on Vettes. How could this happen. Is the fluid likely to keep leaking & getting worst? Never heard of a fluid leak in the car. I want to use the car today but am afraid to make things worse and getting fluid on my carpets. Hate it when you do preventive maintenace and have a problem because of it. I really want to drive the car today, what do you guys think. Thanks, Mike
Old Aug 25, 2024 | 02:52 PM
captain vette's Avatar
captain vette
Take it back to the dealer asap!
Old Aug 25, 2024 | 11:30 PM
B-STOCK's Avatar
B-STOCK
Thats the plan,
Old Aug 26, 2024 | 08:51 AM
lucky131969's Avatar
lucky131969
It's hard to believe you would even contemplate driving the car with fluid leaking inside the car.
Do not drive it. Get it back to the dealer.....and yes, they should pay for the flatbed service, carpet cleaning, and floormat replacement if necessary.
Old Aug 26, 2024 | 09:30 AM
redzg's Avatar
redzg
Did they flush and bleed the clutch, or just syringe change it? At 20+ years old it is quite possible that the rubber seals simply gave up during a bleeding operation. If it’s just the master we should be grateful.
Personally, if the clutch operates well in the driveway, I would top off the reservoir, put a towel on the floor, and drive it to the dealership — I have yet to see a tow, flat bed or otherwise, that wasn’t likely to induce damage. Do not be surprised when the dealer refutes responsibility. Again personally, if I could get them to meet me anywhere between full charge and free I’d be satisfied.
Old Aug 26, 2024 | 10:00 AM
lucky131969
...geez....
Old Aug 27, 2024 | 07:01 PM
B-STOCK's Avatar
B-STOCK
The dealer said they didn't know where the leak was coming from and the next step with the clutch was to change the clutch master cylinder for $1,000+ and go from there. That would be to replace the entire clutch and every part that goes with it. I am 77 years old and had the car since new. Never had a clutch problem even with my first real car, New 66 GTO, Every stop light was a vigorous start. I guess I just have the knack of operation the clutch that would make them last FOEVER. Any thoughts. This is driving me nuts.
Old Aug 27, 2024 | 10:19 PM
mmartinez's Avatar
mmartinez
1000$ sounds a little steep for changing the master cylinder, I would recommend finding somebody else to take your car to.
To Clutch fluid change & problem HELP
