ARP 12pt vs 6pt bolt kits
Old Feb 3, 2003 | 11:52 PM
rwj383's Avatar
rwj383
Default ARP 12pt vs 6pt bolt kits
I've been awaiting ARP's reply to my email on what precisely are the differences (aside from the visual differences) between a 12pt and 6pt bolt of the same material. is there an actual yield difference? torque specs different? Does anyone know the facts? there is definitely a cost difference between the 2 otherwise identical bolts/nuts.
Old Feb 4, 2003 | 01:29 AM
Nitrous Nate's Avatar
Nitrous Nate
Default Re: ARP 12pt vs 6pt bolt kits (rwj383)
I talked to my engine guy and he said there was no diff. between the 12pt. and the 6pt., just the nut. I opted for the 6's since they are cheaper and do the same job. Also from what I researched the 12's are on backorder and will be for a while. Hope this helps with your decision
Old Feb 4, 2003 | 07:00 AM
rwj383's Avatar
rwj383
Default Re: ARP 12pt vs 6pt bolt kits (Nitrous Nate)
well, ARP better have a better reason than 'just a different shape' to charge that much more over the 6pt. Long ago someone that has been using ARP for many years explained some convincing reason to me, and i forgot what it was. Hmmmm...
When i built my motor last year i bought to 12 pt over the 6 pt. Those that i am helping with their motor mods around here have turned to me for this answer. If there isnt one, i will tell them just to buy the 6pt set.
Old Feb 4, 2003 | 07:23 AM
Patches's Avatar
Patches
A buddy and I installed the 6-pt. ARP head studs when we did h/c on both our cars recently and have had zero issues. I have had my heads off several times since and they held the torque with no problem. I'd be interested to hear what the differences are as well.
Old Feb 4, 2003 | 11:17 AM
rwj383's Avatar
rwj383
Default Re: ARP 12pt vs 6pt bolt kits (Patches)
ttt.
some's gotta know....Shirl, you reading the boards this morning???
Old Feb 4, 2003 | 12:04 PM
Phil97SVT's Avatar
Phil97SVT
I think its mainly preference. I got the 12 points because I feel like they are easier to torque down, the socket moves less/less chance of rounding off nuts.
Phillip :skep:
Old Feb 4, 2003 | 12:31 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Re: ARP 12pt vs 6pt bolt kits (Phil97SVT)
Phillip :skep:
:iagree: That's what Tim Cook at Scoggin-Dickey told me. :cool: :cool: :cheers:
Old Feb 4, 2003 | 01:04 PM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Seems I have designed a few nuts & bolts ...........
12 point head reduces the chance of tool slippage.
Smaller head allows for use in confined areas.
A 12 Point design offers the same bearing surface as a hexagon head cap screw or socket head screw of comparable size.
Other features include better torque distribution due to less peak loads and effective use in counter-bored or spot faced applications because of smaller head diameters.
Have a nice day
:thumbs: :D
[Modified by ALLTHROTTLE&NOBOTTLE, 1:09 PM 2/4/2003]
To ARP 12pt vs 6pt bolt kits
