Quick question on my'02 automatic.....
Old Sep 1, 2024 | 05:21 PM
ZR-1 Mark's Avatar
ZR-1 Mark
Default Quick question on my'02 automatic.....
I'd like to have the problematic shift cable here in case it breaks on me at the wrong time...And do I order just the cable or I've read about some bushings ? Any help would be much appreciated, even knowing the best place to order it from....
Thanks in advance, Mark.
Old Sep 2, 2024 | 06:59 AM
vortecman's Avatar
vortecman
Cruising
I just had mine changed and I got it from Parts Geek, part # Wo133-2045 849. All I needed was the cable and it comes with the bushings, it's a GM part.
Old Sep 2, 2024 | 04:56 PM
Ed Ramberger's Avatar
Ed Ramberger
Ed Ramberger
DefaultThat cable housing is going to be brittle and VERY easy to break the cable housing at the shifter side if you deflect it more than the tiniest bit. I would replace it. I would also consider an insulated tunnel plate while it's all apart.
Ed Ramberger
To Quick question on my'02 automatic.....
