I’m trying to pull the flywheel housing to replace it but there’s this brake (?) line holder in my way and I’m not sure if I can move it.
I have the intake off, I’ve lowered the jack from under the engine and the housing is off the
alignment pins but is being just barely blocked by this. If I can’t move it then I think my only other option is to take the clutch off.
if you have any magic tricks I’m all ears,
-Will
I figured it out, the flywheel has 3 points on the edge where it thickens up and one of those was keeping the housing stuck, if you rotate the flywheel you can pull it off.
