Well I am seriously planning on taking my car to get a HEads and cam package in the month or so. I plan on just getting the heads, cam, and pulley and tuning without getting the headers to see what numbers she will put out.
I plan on getting headers and will due those myself after the H/C is complete. Will I need to retune after I get the headers or should the tuning still be fine?
I know it really isn't the wisest thing as I should do everything while it is all apart, but I am kinda interested to see how restrictive the stock manifolds and cats are.
Some thoughts???
I would not recommend it. You will gain 15 to 20 easily with the headers. You are spending the money to increase airflow to the engine and not letting it out properly.. :seeya :seeya
I am with you. Actually, I am considering the same thing. Headers are a separate install and the cost for installing headers does not get reduced if you do it at the same time. I am very interested in this test too.
I would expect to see more gains from the headers after the head/cam install.
Keep us posted. As for me, I've got to get wheels and tires before I do anything else. . . :yesnod:
Headers do have to be unbolted to swap the heads.
Also regarding tuning you will more than likely need to have it retuned as well after the headers are added.
Normally we don't charge extra for header install while doing a head and cam swap, unless there is welding required and then the charge is still minimal.
As for headers on a N/A motor it is suggested to be done because you are taking in more air and you have to get rid of that air just as quick. Without headers you will get backpressure in the manifold which could cause detonation.
As fo headers on blower cars these guys do pick up a decent amount of torque when headers are added to the car.
Re: Heads and Cam w/o Headers?? (Chris@SpeedDemon)
:eek: Oh, crums. . .I guess I will go ahead and purchase my headers. If they already have to come off for the heads to be installed. . .it looks like headers will be on the way!
So much for that thought. I got a great deal on a set of TPIS's that I should be picking up in the nest week or so.
I was just trying to maybe offset the cost by just getting the H/C and tune and due the headers later since it would only cost me my time. I figured a retune might be necessary so that was the main determining factor.....plus the great deal on the headers
:D
