Reduced Engine Power c5 corvette.
Old Sep 8, 2024 | 07:02 PM
Davisfilleman's Avatar
Davisfilleman
Default Reduced Engine Power c5 corvette.
Hi there. This is my first post and I'm still trying to figure out how this all works. I've been reading a lot on past issues for my Corvette, but this is my first post. I am experiencing the dreaded reduced engine power. On all of the stuff that I've been reading I've read that the TPS is usually the issue. I thought I had a vacuum leak before because of a low idle and some bucking, but after reading all of this, I thought that it could've been the TPS sensor. I replaced the sensor and it's still flashing the code. What would be the next step here? Should I clear the code and drive the car? Or is there something else I should replace? It feels like such a hassle and I was so delighted to hear that. It was as simple as a TPS sensor that I needed to replace. But now that that hasn't fixed the issue we're back to square one.
Old Sep 8, 2024 | 08:04 PM
C5VetteKing's Avatar
C5VetteKing
Veteran: Marine Corps
Pull your codes on your DIC.
Old Sep 8, 2024 | 09:20 PM
Dads2kconvertible's Avatar
Dads2kconvertible
What troubleshooting tools and capabilities do you have?
Old Sep 9, 2024 | 07:24 PM
Davisfilleman
@C5VetteKing @Dads2kconvertible Here are the codes I'm seeing.
P1120
P1220
P1516
I just went and picked up a new throttle position sensor and installed it yesterday. I'm not seeing any noticeable change as far as the codes go and I'm still getting a reduced engine power sign on the dash. I'm wondering if I should clear all the codes and start up the engine to see what happens? The throttle position sensors are stored, but then the same two codes are listed and it says pending.
I appreciate the help guys
Old Sep 9, 2024 | 07:26 PM
Davisfilleman
@Dads2kconvertible I did a little bit of research and I just went ahead and replaced the throttle position sensor. I was experiencing some issues that related to the throttle position sensor already and so that was the first thing I tried. I'm thinking testing the battery should be next? But on the gauges it looks like my battery is reading fine.
Old Sep 9, 2024 | 07:52 PM
lucky131969's Avatar
lucky131969
P1120
P1220
P1526
Just clarifying the P1526. Are you certain it is not P1516?
Old Sep 9, 2024 | 07:53 PM
Davisfilleman
@lucky131969 Im sorry. You're right. It is code P1516. My fat fingers must have pressed the wrong one. I apologize and thank you for catching that.
Old Sep 9, 2024 | 08:01 PM
lucky131969
It's troubleshooting time. Do you have a scanner? DMM ?
Old Sep 9, 2024 | 08:03 PM
Davisfilleman
A super nice code scanner, yes. As far as electrical issues go, they are my arch nemesis. Any tools or trouble shooting in that department is a foreign land to me. As far as the troubleshooting process? Also foreign. You guys are the masters
Old Sep 9, 2024 | 08:07 PM
lucky131969
A stricly code scanner will not get it done. You need to monitor a few parameters for the throttle position sensor, and may need to take voltage or resistance measurements. Sounds like you need to find a trusted shop.
Old Sep 9, 2024 | 08:09 PM
Davisfilleman
Im thinking that might be the case too. When it comes to modifications? Mechanical? I can do it myself. This is definitely new to me.
Old Sep 9, 2024 | 11:58 PM
C5VetteKing
I think that’s a sensor that has to be “re-learned” into the system after it has been replaced with a GM Tech2 scanner. It can be replaced, but if it has not been “re-learned” the codes will still in your computer and the Vette will not operate properly.
Old Sep 10, 2024 | 12:27 AM
Davisfilleman
wait you can't replace the TPS without that tool?
Old Sep 10, 2024 | 08:26 AM
lucky131969
Do tell? Please post the procedure for this TPS relearn.
Old Sep 12, 2024 | 05:03 PM
smitty2919's Avatar
smitty2919
https://www.carparts.com/blog/what-triggers-reduced-engine-power/?srsltid=AfmBOorkygvgK4qvpOVkGAKkiihZeWD hGL_I_d1Jrr-yUuF4H6EygfDU
https://www.way.com/blog/p1516-meani...g%20for%20long.
Don't throw parts at it. Need to do some digging on it.
Old Sep 12, 2024 | 05:06 PM
Davisfilleman
Originally Posted by smitty2919
https://www.carparts.com/blog/what-t...-yUuF4H6EygfDU
what would you say is the best route? What's to check? Got a checklist come to mind?
Old Sep 12, 2024 | 05:19 PM
lucky131969
I'm confused. You disclosed that you did not have the equipment or capability to due the troubleshooting.
Old Sep 12, 2024 | 05:25 PM
Davisfilleman
I've got a mechanic coming to check it out. If you guys had any ideas that come to mind right off the bat: "the problem is probably..." I'd just ask him to take a look at it. Right now I'm thinking throttle body. I asked him to check that first.
Old Sep 12, 2024 | 05:51 PM
lucky131969
Good luck with your issue.
To Reduced Engine Power c5 corvette.
