2000 C5 Engine Ticking Sound
Old Sep 12, 2024 | 03:37 PM
Number-6's Avatar
Number-6
7th Gear
Default 2000 C5 Engine Ticking Sound
I drove my 2000 C5 yesterday about 7 miles and heard a loud ticking sound as you can hear in the video when I got back to my driveway. I've noticed this before, but it seemed to go away after driving for a while. The care is stock with 49K, except for a Corsa exhaust. Any suggestions for where I should look to troubleshoot?
I did read about ensuring there are no loose spark plugs that could cause the issue, but I could not disconnect any wires. They were so tight, even a channel lock pliers could not budge them. The wires could be original to the car and I did not want to take a chance on breaking them without a new set to install.
Old Sep 12, 2024 | 03:48 PM
lucky131969's Avatar
lucky131969
https://youtu.be/hklON7fIKEM
Remove the belt and see if the noise goes away.
Old Sep 13, 2024 | 01:44 PM
Midwest19942000's Avatar
Midwest19942000
Agree remove the belt and see if you still have the noise. Sounds like a failed pulley bearing or something rubbing that shouldn’t be. A ticking lifter or rocker would sound much slower at idle.
Old Sep 13, 2024 | 07:37 PM
Number-6's Avatar
Number-6
7th Gear
Thanks for everyone's response. I took another video today immediately after a cold start, and the ticking sound is replaced by a whining sound. Any thoughts?
Old Sep 13, 2024 | 07:52 PM
lucky131969
https://youtu.be/nv3COq_yU7k
Ok, so you did not remove the belt ?
To 2000 C5 Engine Ticking Sound
