What's next
Old Feb 4, 2003 | 01:49 PM
c5 devil's Avatar
c5 devil
Default What's next
I have a 99 vert. automatic with 3.15 gears, blackwing and corsa catback..What should i do next???
FLP headers and x-pipe, or a torque converter....Please help if you have any other ideas i will be happy to hear them.....By the way i can not spend more than 2500$ ......Thanx
Old Feb 4, 2003 | 01:56 PM
cscollis's Avatar
cscollis
Default Re: What's next (c5 devil)
Torque Conveerter and Gears.
3000 or less stall for 3.15
3500 or less stall for 3.42
Or you could do what I did 3000 stall and 3.42's very nice setup.
Then LT headers.
Old Feb 4, 2003 | 01:58 PM
Crushinator's Avatar
Crushinator
With $2500 to spend, I think you'll benefit most from a set of 3.73 gears, LS6 intake and a set of TPIS headers. That's what I'd do anyway. Good luck!
Old Feb 5, 2003 | 03:14 AM
c5 devil's Avatar
c5 devil
Default Re: What's next (QuickSilver97)
Thanx guys....Do you know what kinda times i should be doing with the blackwing and the corsa catback....99 vert with 3.15 gears....and how much time can i shave with the 3.42 and a converter.....thanx
Old Feb 5, 2003 | 06:43 PM
c5 devil's Avatar
c5 devil
:sleep:
Old Feb 5, 2003 | 06:54 PM
Face's Avatar
Face
With good weather and track prep, you should be running high 12's, low 13's.
After a converter and gears you should also pick up a pair of drag radials for the track. Then you'll have mid 12's easily.
Even if you keep your 3.15 rear, don't bother getting a converter smaller than a 3,000 stall. I have a Yank SY3500 and a 3.15 rear. It's a little loose feeling, but is still streetable and took .5 off my E.T. If possible, see if anyone in your area that has done converter will let you take their car for a quick test drive.
Old Feb 6, 2003 | 08:02 AM
c5 devil's Avatar
c5 devil
Default Re: What's next (Face)
well do thanx
To What's next
