6-5 Downshift Grind/Difficult Reverse
Old Sep 25, 2024 | 02:23 PM
Pete Z06's Avatar
Pete Z06
Default 6-5 Downshift Grind/Difficult Reverse
Hey yall, so I’ve recently developed a 6-5 downshift grind, but what’s weird is if I’m going 65/lower rpm it’ll downshift 6-5 just fine but anything above 70ish mph it will grind. Could that be the lockout solenoid? Also, I put in a softer solenoid spring, would that also cause issues? The Trans is definitely worn, near 160k hard miles, but it never has any pop outs or issues going into gear ever. Only this 6-5 new downshift issue. Also reverse is insanely difficult to get into, and once it’s in it does not pop out, but it requires so much force, I think that’s just due to high mileage trans. I also just installed a new mgw shifter replacing my old model that used the stock lower box hoping the lower box was super worn, but that wasn’t it before anyone else asks, it has fresh amsoil torque drive in it, and I’m gonna change clutch fluid again too see if it does anything (motul rbf600) anyway, if someone can confirm a lockout solenoid could cause a downshift grind, before I go crazy and waste another $100 when in reality it’ll need a trans rebuild eventually
Old Sep 28, 2024 | 04:07 PM
Supercharged111's Avatar
Supercharged111
Reverse sucks in these, but it sucks more in the 6060. I got my car with 99k and reverse had already been replaced. A year after I got it, I too fixed reverse. It's the first thing you see when you open up the trans.
Old Sep 28, 2024 | 04:52 PM
rrwirsi's Avatar
rrwirsi
No thoughts on the downshift issue but the reverse gear easy is always an issue with my C5 base since purchase 10 years ago. My workaround in the M6 is first put in neutral, wiggle the shift many times and then put in reverse gear. Seams to work for me.
Old Sep 29, 2024 | 01:16 PM
Pete Z06's Avatar
Pete Z06
bummer, the downside thing is tripping me out. So I can downshift around 65mph in 6th but around 70 it’ll start to fight back and grind. It’s also having more trouble finding reverse, it’ll be in the slot but not engaged. Now I beat the **** out of it so what do I expect. But it never grinds or pops out while in gear or when upshifting ever, oh well guess I’ll just live with it
Old Sep 29, 2024 | 01:56 PM
helga203's Avatar
helga203
If you are able to get the rear end up in the air and try to put it in rev with clutch in and tire starts to turn you have a dragging clutch and the only fix is replace. Same if you try first.
Old Oct 3, 2024 | 12:37 PM
Pete Z06's Avatar
Pete Z06
it’s a fully built car. Tick master, new oem slave, and ls7 clutch correctly broken in for 500+ miles before aggressive driving. But the trans is original with 157k. Clutch stuff done maybe around 131-3k I forgot. But it still drives great going in first and all the rest. Gets into 2, 3, and 4 at 7k rpm no problemo. I just think from aggressive driving while racing it’s hurt the trans, maybe bent the crappy aluminum shift forks. Guess I’ve accepted that’s the result of my driving haha, maybe in a few years I’ll rebuild it if it doesn’t get any worse.
Old Oct 4, 2024 | 02:08 PM
spfautsch's Avatar
spfautsch
Sorry I haven't been watching the forum in a while. I had the exact same problem (downshifts to 5th at > 65mph). I didn't see anything obvious when I went through it, but you're likely going to want to replace 5th and the slider because the engagement teeth are going to be pretty chewed up.
I replaced all frictions and rings as well as 5th gear and the syncro slider and downshifts to 5th are smooth at any speed now. But I will add that I'm not sure running synthetic fluid in these is a good idea, and I suspect that's probably what was in mine (from a previous owner). Not because it's reported to damage the paper blockers, but because it's designed for automatic transmissions with hydraulic clutches. Here's why I filled with regular Dex 3 - TDP does not recommend any type of synthetic in the T-56 or the 6060. See here.
Old Oct 4, 2024 | 04:17 PM
Pete Z06's Avatar
Pete Z06
I made the grave mistake of putting manual synchromesh in when buying the car. Caused 4th gear to grind when going from 3rd. Torque drive is dex 3 rated/compatible, that’s why I put it in. Got rid of the 4th gear issue shortly after getting used to the fluid. I also drive the car aggressively and regular atf would get fried under the conditions I drive. Amsoil is tough stuff and lasted a year just fine. When racing many times I try to bang from 3rd to 4th and it just wouldn’t go into gear and I’d force it and nothing. Made it even worse getting into first and reverse, literally impossible, but it heals itself over time funny enough and now it’s back to normal since the last time. While the synchro may be bad, I’m sure my aluminum forks are bent too. But it goes from 4th to 5th just fine so I’m not worried about a little specific downshift being my only trans issue at 158k miles. Thanks for the input
Old Oct 4, 2024 | 05:17 PM
spfautsch's Avatar
spfautsch
That may be true, but it's made with synthetic base stocks, which have significantly higher lubricity. Also, the Dex 3 specification was developed for autos with hydraulic clutches. The frictions and cones in the synchros were designed for dino ATF, which is why TDP recommends it over anything made with synthetic stocks.
I'm sure there are others that have this issue but may never notice it due to not downshifting quickly to 5th. I tend to use 5th when in traffic on the interstate instead of the brakes. After a while, any time there was "spirited" cornering on the horizon I started trying to skip directly to 4th, until I accidentally hit 2nd once. Near death experience.
To 6-5 Downshift Grind/Difficult Reverse
