Fuel Trims VS Air
Old Sep 27, 2024 | 04:42 PM
Schmidtstain's Avatar
Schmidtstain
Default Fuel Trims VS Air
I find this curious, was wondering if anyone could explain the association further. I start the video with the hood open and my fuel trims are acceptable (at least better than they've been). The MAF reading is slightly higher than displacement. I then close the hood, and fuel trims climb along with the MAF decrease to below ideal numbers (not on video, but I did get down to 5.04 g/s). This doesn't make sense to me. Not sure why more air with hood open would translate to lowering trims. I've checked for a vacuum leak 6 times in 5 different ways. All of those checks are obviously with the hood up. Well, it seems that with the hood up I don't have an issue..... Wondering if a hose is getting pushed/pinched/smashed when the hood closes?
Update: This was a bad MAF. I had replaced with a new MAF just prior to this but it ended up being faulty. Warranty replaced this one, and this issue went away.
Old Sep 27, 2024 | 06:45 PM
lucky131969's Avatar
lucky131969
Fuel trims and MAF
What else about the environment changes when you close the hood from the engine's perspective?
Old Sep 27, 2024 | 06:49 PM
Schmidtstain
I have a feeling this is a rhetorical question, I get there is less air now that the hood is closed. But that would be the only thing. My thought was less air should equal less fuel to balance, but the trims go up
Old Sep 27, 2024 | 07:32 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Fuel trims and MAF
Didn’t you change your MAF sensor recently ??…was it the same as your old one ??…if not maybe this one sits higher and not knowing how much clearance there is between the top of the MAF and the hood maybe it’s “tweaking” the sensor when you close the hood…never seen this before…maybe try a little bit of clay or something similar to check.
Old Sep 27, 2024 | 07:56 PM
Schmidtstain
I did change it, it's in pretty much the exact same spot (this intake has it down low, I think some have them up high). I tried to keep an eye on it as I was closing the hood to see if it looked like it was shifting something. Clay is a good idea.
Old Sep 27, 2024 | 07:58 PM
C5 Diag's Avatar
C5 Diag
We used clay a lot in the airline industry to check for clearances like main landing gear doors and other things like that…even bubble gum would work.
Old Sep 27, 2024 | 09:30 PM
Schmidtstain
Just thought of something while talking it over with my dad - in that video the hood isn't even fully closed. It's really just resting on the latch as I didn't close it hard enough. I'm not sure that ANYTHING would be even close to touching at that point. The last 2 seconds is me pressing it close manually.
Old Sep 27, 2024 | 09:39 PM
C5 Diag's Avatar
C5 Diag
I would just check all the connections between the MAF and Throttle Body.
Old Sep 27, 2024 | 10:05 PM
Markolc1981's Avatar
Markolc1981
I'd be poking around searching for a vacuum leak somewhere. My guess is you have unmetered air entering the intake manifold somewhere.
Also possible you could have an exhaust leak before the O2s.
+10-25% Fuel trims isn't right.
This is all assuming your MAF sensor is working accordingly.
5.1-5.5 g/s is what my stock motor measured at warm idle 725 RPM.
Old Sep 27, 2024 | 10:16 PM
Schmidtstain
1. Based off other info I completely agree. Intake manifold has been removed and gaskets replaced.
2/3. Have heard that as well (I do have aftermarket cold air intake, figured "some" additional fuel trim normal). I did check for exhaust leak with smoke method through tailpipes (as well as carb/brake cleaner + smoke test engine)
4. New MAF as P0101 was original code (whole other thread, seems P0171/74 were driving codes instead of P0101)
5. I do occasionally see those MAF values at idle, but my idle is 795-830ish rpm usually. That is anywhere from 5.3-6.1 g/s MAF.
Old Sep 28, 2024 | 09:21 AM
Gordy M's Avatar
Gordy M
Which cold air intake are you using, Veraram, License plate area type, or -Calloway type? If isn't a true cold (ambient)air intake closing the hood would bring heated (engine) air thru the MAF, causing a drop of oxygen entering the TB
Old Sep 28, 2024 | 09:26 AM
Schmidtstain
​​​​​​ It's the KN version, somewhere in between. It has a small 1" by 8" slit that gets cut into the top of the shroud in front of the radiator. Definitely getting less oxygen with hood closed.
Old Sep 28, 2024 | 09:54 AM
lucky131969
​​​​​​ Definitely getting less oxygen with hood closed.
I do not see how this is possible unless your car is in a plastic bag with sealed outlets for the exhaust.
Old Sep 28, 2024 | 10:03 AM
Schmidtstain
Would it be reasonable to think that the intake would be at a minimum "struggling" to get air in a closed hood vs open hood scenario? If that was a potential, MAF reports lower number but the rest of the air that the engine needs could be pulled in through my theoretical vacuum leak? The unmetered air then causing the trims to go up?
Old Sep 28, 2024 | 10:18 AM
lucky131969
No, that would not be reasonable.
Old Sep 28, 2024 | 10:25 AM
Schmidtstain
No, that would not be reasoable.
Why not though? I'm just trying to understand this. For example me breathing open air vs breathing through a straw. I'd say that's reasonable to make the jump
Old Sep 28, 2024 | 05:57 PM
lucky131969
Good luck on your quest
To Fuel Trims VS Air
