leaking coolant from bell housing?
Old Sep 27, 2024 | 04:53 PM
chiefkeith's Avatar
chiefkeith
Default leaking coolant from bell housing?
recently finished putting a refreshed ls1 in my c5(old one blew), and i’m getting ready to start it for the first time but im leaking coolant from what looks like the upper part of the torque tube/bellhousing. anybody know what could be leaking? the only thing in that area that i touched is the slave cyl, it was cracked inside. all the gaskets on the engine and adjacent parts are brand new.
engine mods incase it matters:
ported 243 heads, ls9 gaskets, comp cams pushrods, upgraded rocker arm trunnions, arp head bolts
TXS bald eagle boost cam
ls6 intake mani
15% UD harmonic balancer/arp crank bolt
possibly a couple more i’m forgetting but those are the only ones that i think could in any way relate to this issue. thanks!
Old Sep 27, 2024 | 05:17 PM
G_Loc's Avatar
G_Loc
Might be coming from the heater core lines. They run along the firewall and enter the cabin somewhere behind the engine. Did you remove them? If not maybe they got banged up during engine removal or installation.
Old Sep 27, 2024 | 05:24 PM
SilverC54me's Avatar
SilverC54me
Also check the rear engine steam pipe connections at the back of the heads.
Gary
Old Sep 27, 2024 | 05:39 PM
lucky131969's Avatar
lucky131969
ls6 intake mani
Do a pressure test it will reveal itself.
Old Sep 27, 2024 | 07:27 PM
chiefkeith's Avatar
chiefkeith
i did not remove them but u could be right. i’ll check them out thanks
chiefkeith's Avatar
chiefkeith
Gary
will do thanks!
Old Sep 27, 2024 | 11:57 PM
vette4fl's Avatar
vette4fl
will do thanks!
Did you put new orings on the steam plugs?
Old Sep 28, 2024 | 02:10 PM
chiefkeith's Avatar
chiefkeith
yes brand new rings, gaskets, etc on everything
Old Sep 28, 2024 | 02:43 PM
helga203's Avatar
helga203
Didn't matter what leak i had. Oil or anti, I always used the die worked every time.
To leaking coolant from bell housing?
