AGM battery charging basics ?
Old Oct 5, 2024 | 02:19 PM
killain's Avatar
killain
Oldtimer
Default AGM battery charging basics ?
Two weeks agon I went out and found my Optima Red Top battery of 2 years old had died. So I thought that Ok, it was just the luck of the draw that it went bad. I purchaed a brand new Optima 75/25 Battery and, I do keep my 2003 on a trickle charger if I'm not using my car for 2 weekks or more. I checked the charge once installed, @ 12.73 volts and I took the charger off (It is NOCO Genius-1 charger set on AMG and it has a small red/orange/green light to indicate the charge leval. I left it on overnight and the next moring I measured again and it had 12.75 volts, I saw something about the AMG batteries that suggested the new AGM battery needs to discharge once or twice down to 11.8 Volts to condition the battery to acept a higher voltage Truth or Not ?
Old Oct 5, 2024 | 05:09 PM
Dads2kconvertible's Avatar
Dads2kconvertible
Optima has the specifications for charging Optima batteries. https://www.optimabatteries.com/support
Read the answer to "Charging Optima AGM batteries".
I expect your Noco Genius meets those but consult your owner's manual to be sure and contact Noco if you have questions about it.
I've never heard of discharging to a certain state of charge to condition a modern auto battery to accept a full charge.
Old Oct 5, 2024 | 08:37 PM
killain's Avatar
killain
Oldtimer
Perhaps I'm a little confused. I just thougfht that it's resistens to taking a greater charge out of the box. I had a Red Top 75/25 in my last C5 and it was fine for 4 years, which is about the most I've ever seen any battery lasted !
Thank you,
Old Oct 6, 2024 | 11:15 PM
lionelhutz's Avatar
lionelhutz
What are you expecting to measure for voltage?
I put my charger on a timer and only charge for an hour a day.
Old Oct 7, 2024 | 09:11 AM
Gordy M's Avatar
Gordy M
If you use a trickle charge the AGM batteries need 0.75V while the regular battery wpi;d use 1.25V charger.
To AGM battery charging basics ?
