Hello, I have a c5. 2001 base, I just recently change my rear wheel to a different used set , after doing so I get a dic message of left rear and right rear tires are flat, of cilurse the are not flat tire store said to bring car back in, ant ideas
Go through the programming sequence for the TPMS sensors again.
If the tire store put new sensors in - were they working when you left the store?
The TPMS system on the 2001 is different than the 2000 and earlier and should be a little easier to deal with. This thread has all the information you or the tire tech should need.
Thanks for you replys took it back to tire store and tge two tpms. Sensors on both rear wheels were bad, had replaced and thry work great, shout out to discount tire for their awesome work at a fair price
