C5 Corvette brake fluid flush
Old Oct 11, 2024 | 10:12 AM
Gcannino's Avatar
Gcannino
7th Gear
Default C5 Corvette brake fluid flush
Good morning everyone having the brakes flushed on my C5 my question is mechanic is going to use a vacuum bleeder and completely bleed the system will this put fresh fluid into my ebcm my mechanic says yes but I am inclined to disagree with him thank you gary
Old Oct 11, 2024 | 11:31 AM
lucky131969's Avatar
lucky131969
Originally Posted by Gcannino
.... but I am inclined to disagree with him
Based on what? If the fluid is being drawn through the system to the caliper, how does it not go through the EBCM?
Old Oct 11, 2024 | 01:48 PM
BHauber's Avatar
BHauber
You have to activate the ebcm with a code reader or computer to cycle the new fluid through. Or drive it hard and get the abs active. Maybe a few power slides on slippery area.
Old Oct 11, 2024 | 02:08 PM
lucky131969
A "code reader" will not perform an "automated bleed". You need a capable scanner or Tech2.
An "automated bleed" is only necessary if there is reason to believe air has been introduced upstream to the EBCM.
Pointless if you are trying to remove air from the system, or just bleed the brakes. All this will do is exercise the system.
Old Oct 11, 2024 | 02:14 PM
BHauber's Avatar
BHauber
I have a mid level code reader or scanner that will activate the ebcm. 100 dollars. The op was not asking about air in the system he just wants new fluid in his ebcm.
Old Oct 11, 2024 | 02:26 PM
lucky131969
Right, and power slides won't help with that
...and the OP wants the fluid out of the EBCM.....but does he know why, or if it is even necessary? ......or how the service manual speaks to the subject?
Post your scanner model for the other DIYers.
Old Oct 11, 2024 | 02:32 PM
BHauber's Avatar
BHauber
Foxwell NT630 is the scanner and sliding the car with stability control on will activate the ebcm to try and correct the slide along with cutting throttle and or adjusting timing. Activating the ebcm helps keep fresh fluid in the module and keeps the valves from sticking.
Lucky have a nice day bickering just screws up the thread for others.
Old Oct 11, 2024 | 03:08 PM
lucky131969
Sorry you feel that way. I sometimes forget we have entered an age where fact-checking information....or just confirming if a train of thought makes sense... is considered reprehensible.
Old Oct 11, 2024 | 08:23 PM
nitromainia's Avatar
nitromainia
Automated bleed
The Real Deal
Pushes new fluid through the Entire System
Very important as these cars are now Over 20 years old
Brake Fluid is Hydrophilic
Total Flush of Fluid is Critical to Maintain the integrity of the Steel lines which are subject to internal corrosion
Save The Wave​​​​​​
USA-1
Old Oct 11, 2024 | 09:57 PM
Dads2kconvertible's Avatar
Dads2kconvertible
The OP is asking if the EBCM is somehow closed off when the ABS is not being activated.
If it isn't, his mechanic's method is fine.
If it is, his mechanic's method will leave old brake fluid inside the EBCM.
Old Oct 11, 2024 | 10:33 PM
Smoken1's Avatar
Smoken1
The EBCM has no brake fluid in it.
The BPMV has fluid passing through it
Old Oct 13, 2024 | 11:58 PM
jim993's Avatar
jim993
In my view, the OP's question is answered by Smoken1.
That said, I have changed brake fluid six times, twice by pressurizing the master cylinder, four times using speed bleeders, by far the easiest method. I do not worry about fluid left in the EBCM.
Meanwhile for track guys, I have long used ATE Typ 200 brake fluid.
https://thebuildjournal.com/tech-gui...parison-guide/
Old Oct 14, 2024 | 01:42 AM
James Dean's Avatar
James Dean
Once a car's Brake Master is about 8 years old you need to be careful with their seals. Using a pressure bleeder that puts fluid and pressure at the BMC cap can damage your seals very easily if using a high PSI.
The same can be said for a vacuum sucking at the brake lines. I would recommend using the Advanced Scan Tool (not a code reader...) to do the automated bleed that does force a lot of fluid and air out the system. It does a good job and with a hand style fluid pump you can get everything handled very easily.
To C5 Corvette brake fluid flush
