Piston Ring Orientation
Old Oct 13, 2024 | 08:30 PM
96Formula6spd's Avatar
96Formula6spd
Default Piston Ring Orientation
Hey everyone. I am putting my LS6 back together but I am having a hard time finding the orientation that the rings are supposed to go. Cant find anything anywhere. One place just said space the over one inch apart. Do LS pistons have a certain way to clock the piston rings.
Old Oct 14, 2024 | 10:20 AM
mmartinez's Avatar
mmartinez
Most piston ring gaps are supposed to be 180 degrees apart the top ring gap should be on the side of the piston facing the outside of the engine while the second ring should be facing the inside of the engine. You should also have 90 degrees difference for the oil rings.
