ARP 234-3724, head bolts
Old Oct 14, 2024 | 01:41 PM
Pipedream's Avatar
Pipedream
Default ARP 234-3724, head bolts
Looking for advice/opinions.
Did a search and came up handed. Anyone ever use these?
Any help much appreciated.
Old Oct 14, 2024 | 02:20 PM
vette4fl's Avatar
vette4fl
ARP makes great fasteners. What type of advice are you seeking?
Old Oct 14, 2024 | 02:30 PM
Pipedream's Avatar
Pipedream
Basically ...has anyone used these and what was the experience from it.
I have used the ARP studs for heads but never the bolts.
Old Oct 15, 2024 | 10:42 AM
frodo84's Avatar
frodo84
Uneducated autodidact
Studs are the way to go IMO.
Old Oct 15, 2024 | 11:37 AM
lucky131969's Avatar
lucky131969
Why?
Old Oct 15, 2024 | 12:15 PM
helga203's Avatar
helga203
Im not trying to steer you in anyway, but what application are you using them for??
Just to let you know i ran stock bolts 13lbs of boost for 40k. Broken top ring land ended me engine and heads didnt lift. You just cant use original stock
bolts Thats some good money for N/A if that's your goal. Factory head gaskets also
Old Oct 15, 2024 | 12:37 PM
vette4fl's Avatar
vette4fl
Originally Posted by lucky131969
Why?
Studs are easier on the threads, which is especially valuable in an aluminum block. They are installed with minimum rotational force. Secondly, studs provide an even and more accurate clamping force because they do not suffer rotational torque, only vertical torque. As a result, they can be reused frequently and are a hell of a lot easier to tighten, and remove.
Old Oct 15, 2024 | 12:56 PM
lucky131969
Yep.
Old Oct 15, 2024 | 01:21 PM
Pipedream's Avatar
Pipedream
The reason I am asking, specifically about the bolts is... everyone is back ordered for the studs, with no exact answer as to when they will be back in stock. The ARP bolts I can get right now.
Old Oct 15, 2024 | 01:27 PM
lucky131969
Probably would have helped to lead with that information. Seems like your choice has been made for you if you wish to proceed with your project in the near future.
Old Oct 15, 2024 | 05:05 PM
vette4fl's Avatar
vette4fl
The GM bolts are a lot less expensive and work fine. If you’re planning future tear downs, I would go with the GM bolts to get it done now, and buy the studs as soon as they are available for next time. I try to have all my parts on the shelf (in the very back of the shelf hidden from you know who) before I begin work. Hoarding parts is part of the fun, lol…
Old Oct 15, 2024 | 05:29 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
GM bolts, ARP bolts and ARP studs all work well. I agree with using studs for the reasons above and have used them on my builds. From a perspective of handling power / cylinder pressure all 3 would work great on my heads and cam car. I like studs as the chances of pulling the threads out of the block and needing a time sert is much lower.
If you are using GM bolts be sure you have the tools needed to follow the torque to yield instructions.
Old Oct 17, 2024 | 08:42 AM
Pipedream's Avatar
Pipedream
Thanks for the reply... hope you are doing well... this is Scott, Mike Frnka's friend. We all ran together in North Atlanta back in the day, good to see you are still in the game.
Old Oct 17, 2024 | 11:43 AM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
That's been a minute. Hope you're doing well. Still in Atlanta if you are in the area drop me a PM.
Old Oct 17, 2024 | 01:09 PM
C5Mat's Avatar
C5Mat
I used the bolts on my car, zero issues. Follow the instructions and make sure the bolt holes are clean and dry before you lube then install the bolts.
To ARP 234-3724, head bolts
