C5 EBCM removal help
Old Oct 17, 2024 | 11:57 AM
Rawb's Avatar
Rawb
1st Gear
Default C5 EBCM removal help
Hello, I am trying to remove my EBCM off the pump and it wont budge. First let start with the module isn’t located in my engine bay it’s located near the rear suspension.
After removing all the screws it’s won’t come undone, I’ve used flatheads and even a wonder bar.
This is the module before I started working on removing it.
Old Oct 18, 2024 | 12:57 AM
Moved to C5 Tech for help.
Old Oct 18, 2024 | 07:49 AM
lucky131969's Avatar
lucky131969
Always helps if you put your model year in your sig.....obviously you have a 97 or early 98. Posting pics before you started disassembly is not helpful. Post pics of your current state.
Old Oct 18, 2024 | 09:22 AM
OUTAKTRL's Avatar
OUTAKTRL
On my 2002 I used a small spackle knife. Very thin. U need to go around the top upper edge of the ebcm to separate it. Very carefully.
To C5 EBCM removal help
