99 HVAC upgrade
Old Oct 22, 2024 | 05:10 PM
Dirty Dog's Avatar
Dirty Dog
Default 99 HVAC upgrade
My C5 started life as a base m6 coupe. It's a had a lot done to it, mostly in the driveline. I've swapped to a double DIN console and head unit, but I still have the base HVAC controls. I know many of these C5's came with actual climate controls and I assume I'm not the first to think it would be nice to upgrade. What is involved in this upgrade?
Old Oct 23, 2024 | 12:14 AM
Moved to C5 Tech.
Old Oct 23, 2024 | 08:14 AM
redzg's Avatar
redzg
I have not done it, nor have I seen any write ups for it, but a decent understanding of the components involved indicates it’s a lot.
In addition to the digital controller, the air handler — the big black plastic assembly that takes up half the area under the dash — is different, with two separated blend doors instead of one common blend door. You’ll have to add multiple sensors under the hood and in the dash, plus the wiring to those sensors. Compressor, condenser, accumulator, and refrigerant lines should be the same, but would take some research.
Old Oct 23, 2024 | 08:26 AM
lucky131969's Avatar
lucky131969
Originally Posted by Dirty Dog
... and I assume I'm not the first to think it would be nice to upgrade.
Actually, you might be. Most just buy a C5 with auto climate control...they are plentiful, and available in every color.
The complexity really depends on two things: 1) if the ducting and evaporator configuration is common, 2) if the interior wiring harness is common.
To 99 HVAC upgrade
