Loose Seat Repair
Old Oct 27, 2024 | 09:17 PM
02RedMetallic's Avatar
02RedMetallic
Default Loose Seat Repair
So I changed the washers on both tracks which fixed the loose seat issue but now the seat barely moves. So yes I made sure both sides were even, also made sure where you install the washers were moving freely on the rod and also used white lithium grease made sure everything was even again I did not mix up the rods as I installed one at a time. Has anyone had this issue or know why the seat does not move too good or at all? Very weird moves sometimes and sometimes it won’t move at all. When I first installed it to test wouldn’t move at all. I took the seat out checked some stuff even checked the fuses everything was fine. Installed seat again worked a little but very sluggish took seat out again double checked measurements reinstalled still very sluggish makes no sense anyone have this issue? What did you do if anything to rectify? Or is this something that happens when us DIYers attempt this stuff on these cars lol!!!
Old Oct 27, 2024 | 09:51 PM
Moved to C5 Tech.
Old Oct 28, 2024 | 01:29 PM
lucky131969's Avatar
lucky131969
Old Oct 28, 2024 | 04:10 PM
SilverC54me's Avatar
SilverC54me
You have the screw drive out of alignment between the sides. Another possibility is the flexible shaft are not installed properly.
Gary
To Loose Seat Repair
