C5 corvette is knocking
Old Oct 30, 2024 | 06:03 PM
Nikita_14's Avatar
Nikita_14
1st Gear
Default C5 corvette is knocking
I have a 2002 c5 corvette with an auto trans and I can’t figure out why it’s knocking. The knocking tends to get faster when revving in the lower rpms and silent in the higher rpms. The whole car shakes but it’s got an upgraded cam so I’m not sure if it’s normal or not. The knocking also becomes barely noticeable from the outside when the car is warmed up. Any help would be great thanks!
File Type: mov
Old Oct 31, 2024 | 12:50 PM
helga203's Avatar
helga203
Oh boy, you have some work in front of you. That sounds like the drive train damage. To me most likely lifter or rocker arm. Start by pull rocker cover.
Old Oct 31, 2024 | 12:57 PM
lucky131969's Avatar
lucky131969
Lifter and rocker arms are not part of the drive train though......
Old Oct 31, 2024 | 12:59 PM
helga203's Avatar
helga203
Valve train . Im on a bottle of vodka. Thats how i pass my time sitting home listening to wife bitch at me for drinking..
Trust me that's coming sooner then later.
Old Oct 31, 2024 | 01:02 PM
lucky131969
First things first. If you have a knock or loud tap in the engine.......high rpm reving can only make it worse
Start simple
-pull the belt an run just to be sure nothing exterior rotating is causing the issue
-use a mechanics stethocope to isolate the noise
-use an IR thermometer on the exaust to see if you have a colder cylinder
lucky131969
Old Nov 1, 2024 | 07:50 AM
cdee63's Avatar
cdee63
2024 C5of the Year Finalist - Unmodified
It isn't just piston slap? My 2K auto has a very distinct knock when cold started, can really hear it started in the garage. Goes completely away after a few minutes though it sounds as if yours does not go away.
Old Nov 1, 2024 | 08:53 AM
Chevy Cust Svc's Avatar
Chevy Cust Svc
If you're unable to pinpoint the knocking sounds, we may suggest bringing it to a Chevrolet dealership to have a deeper diagnosis performed to figure out the cause. Our team can help with that should you need it. Simply send us an email to socialmedia@gm.com to get started.
To C5 corvette is knocking
