CV Axle Replacement Question
Old Nov 10, 2024 | 09:30 PM
LannyL81's Avatar
LannyL81
Default CV Axle Replacement Question
Question is: when changing out the axles does the diff need to be drained first?
I have watched a couple of videos and no fluid came out of the diff when the axle was pulled out, and nothing was mentioned about draining the diff, but I know that these YouTube videos do not always show everything that is done.
Just thought I would ask before I do the replacement as I would rather not drain the diff fluid out if I do not have to.
Old Nov 11, 2024 | 08:09 AM
mykream's Avatar
mykream
No, you don't need to drain the fluid for an axle change.
Old Nov 11, 2024 | 08:22 AM
LannyL81's Avatar
LannyL81
Thank you for the confirmation.
Old Nov 15, 2024 | 11:05 PM
ncali's Avatar
ncali
you do need to grease the splines when installing them in the hub
Old Nov 18, 2024 | 07:23 AM
LannyL81's Avatar
LannyL81
Absolutely....
To CV Axle Replacement Question
