I just bought the cold air intakes from Mid America that replace the factory inserts on the front end of the car. They came with no instructions. After climbing under the car and looking around under the hood, I've come to the conclusion that I can't see or feel any screws that hold the inserts in. Has anyone installed these that would care to share the secret? I also have the Z06 screens that are inserted in front of the intakes once intalled. Thanks for your help.
Re: Cold Air Intakes - How To Install? (curtowens)
One way to do the installation is to follow the instructions posted in the Tech Tips under "Tools". Go to "West Coast Corvettes Cold Air Screens Installation".
Another is to remove the radiator shroud and go through there or
Remove the front brake caliper cooling ducts and then remove the wiring harness retainer clips.
Once you access the fog light covers then remove the 2 top clips on the stock grill/covers, then the grill/cover screws and remove. Install your open air covers and reassemble. The tech tip instructions will detail the grill/cover and fog light disassembly and reassembly better.
Hope this helps
Good luck!
:thumbs:
You might get some good tips by looking at the VARARAM web site. They did have complete installation instructions that could give you a pretty good idea.
Re: Cold Air Intakes - How To Install? (ndirishr1)
the two tips above are good advice. I have a write up floating around here somewhere, but I always have trouble finding it. I've posted it several times here, in C5 General, and the Parts for Sale sections. :seeya
Can you believe that I took the car with the inner grills to the local Chevy dealer and asked them to install them. I got a call several hours later suggesting that I take the car to a body shop because they felt they were going to have to pull the front of the nose cone off the car to make the swap! I couldn't believe it. I may give it a whirl myself with the instructions provided above and in the tools section on this forum. I did put the outer Z06 screens on. So I look good, I'm just not functional. Does anyone know if the Z06 has these functional grills installed from the factory or is the screen a dress up item as well?
You might consider sending the Cold Air Screens back, drilling out the existing fog light shrouds to allow air flow, then installing the Z06 screens. It achieves the same result and saves the hassle of replacing the shrouds. :)
Good idea no top...except in my haste to beautify the car I already installed the Z06 front screens!!! :rolleyes: I did that before I realized what an unGodly hassle it is to replace the inner shrouds. With these screens being held in by double sided tape, I dont think I can pull them off and have them reinstalled and feel like they will hold. Oh well, live and learn. :cuss
