FINALLY finished my Nitrous install: links
Old Feb 6, 2003 | 10:30 PM
jeffh355's Avatar
jeffh355
Default FINALLY finished my Nitrous install: links
So I finally finished installing my Nitrous system. I ran all the wiring to the back of the car to a separate fuse box. Also used the NX switches in the ashtray area. These pix are huge as I'm still learning to post to my web site so dial up beware http://jeffhess.ipsinc.us/allunderhood.jpg http://jeffhess.ipsinc.us/allunderhood.jpg http://jeffhess.ipsinc.us/nosbottle.jpg http://jeffhess.ipsinc.us/indatrunkbottle.jpg http://jeffhess.ipsinc.us/gaugestuff.jpg http://jeffhess.ipsinc.us/underhoodstuff.jpg
BTW: Took my car to MMS to be Dyno Tuned before I "pushed the button", but I have a dead #1 cylinder at idle.... so the head is coming off now and if it turns out to be ugly I'll have Al build me a better toy.
[Modified by jeffh355, 9:42 PM 2/6/2003]
Old Feb 6, 2003 | 11:38 PM
hrdtopv8's Avatar
hrdtopv8
Default Re: FINALLY finished my Nitrous install: links (jeffh355)
That is schweettt!! Very nice install.. :cheers: I'll be praying that you have a dead cylinder so you can build a bigger monster.. :p:
Old Feb 7, 2003 | 03:28 AM
JOHNNY P.'s Avatar
JOHNNY P.
From: IF YOUR BIG DOLLAR PROJECT DOESN'T RUN 9'S OR BETTER ....BURN IT ! SHUT YOUR MOUTH AND GRAB A LANE ! CHICAGO IL. -------- HOME OF THE FASTEST STREETCARS BARNONE !
WOW ! Are you an Electrical Engineer ? That wiring job is very clean and perfect it came out pretty nice. :yesnod: :auto:
Old Feb 7, 2003 | 05:41 AM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Default Re: FINALLY finished my Nitrous install: links (JOHNNY P.)
Clean install. :cheers:
I am curious how the nitrous effects your temp sensor that is downstream...
Old Feb 7, 2003 | 08:07 AM
jeffh355's Avatar
jeffh355
Default Re: FINALLY finished my Nitrous install: links (C5-VERT)
I thought the same thing. NX "claims" it will have no affect and this system has been used on the camaros for a while now with no problems?? Too bad I can't test it yet!!
Old Feb 7, 2003 | 08:09 AM
vstella's Avatar
vstella
Very clean install! :yesnod: I know what it's like to lose a cylinder :rolleyes: I lost #7 and now I'm building a 382..;)
Best of luck..
Old Feb 7, 2003 | 09:23 AM
vettedevil's Avatar
vettedevil
Looks like a nice job but I think you have the bottle at the wrong angle as far as the pickup tube inside the bottle, the line should face down or you wont get full use of the juice, at least that is what I was told. check with someone else Im still new with this stuff :steering:
Old Feb 7, 2003 | 09:28 AM
jeffh355's Avatar
jeffh355
Default Re: FINALLY finished my Nitrous install: links (C5Coup)
As I'm new to this myself I "thank you" for the comment. Anybody else? I will call NX today to find out but it makes sense. :cheers:
Old Feb 7, 2003 | 09:33 AM
ICULUKN-C5's Avatar
ICULUKN-C5
awesome pics.. But is this a wet kit? If so why are you spraying so far from the throttle body?
Old Feb 7, 2003 | 09:44 AM
jeffh355's Avatar
jeffh355
Default Re: FINALLY finished my Nitrous install: links (ICULUKN-C5)
Is this a wet kit? If so why are you spraying so far from the throttle body?
This is a wet kit from NX. It's their Gemini kit. It replaces the factory MAF housing ends and sprays through the inside of the unit. It was developed for the F-Body cars. At the SEMA show this year the guys at the NX booth talked me into this unit for the Vette and showed me the data they had on flow and mixture, etc You guys are starting to scare me a bit.... I hope it works okay.
Old Feb 7, 2003 | 09:48 AM
Bill Reid's Avatar
Bill Reid
Suweet :yesnod:
Old Feb 7, 2003 | 10:06 AM
Closer_2001's Avatar
Closer_2001
Can you give a list of parts, or a link to the supplier for the fuse panel. I had planned to do this exact thing before deciding to sell my car (and my nitrous kit). As many can see, with the window switch, FPSS, etc, etc, the wiring can get a little messy. The separate juice panel makes it much cleaner. Great Work!!!
:cheers:
Old Feb 7, 2003 | 10:11 AM
jeffh355's Avatar
jeffh355
Default Re: FINALLY finished my Nitrous install: links (Closer_2001)
[QUOTECan you give a list of parts, or a link to the supplier for the fuse panel. [/QUOTE]
Thanx for the kind words: http://www.painlesswiring.com/fuseblock.htm Fuse box part number 70107, came from web site, and I ordered it from AutoZone.
Old Feb 7, 2003 | 10:29 AM
Reckless808's Avatar
Reckless808
Very nice installation :yesnod:
The way you have your bottle is backwards for the direction it is mounted. The optimal mounting is front-to-back, but you have space limitations. With the side-to-side mounting, you should face the outlet (where the N2O comes out) toward the rear of the car. This way, the nozzle inside the bottle will be directed toward the back.
The tube inside the bottle actually angles down to the bottom and is biased to one side. The tube picks up nitrous from the bottom of the bottle on the same side of the outlet hose.
With your current mounting, as you accelerate, the tube may not get good pick-up as it is currently pointed toward the front of the car. Make sense? :D
Old Feb 7, 2003 | 11:39 AM
jeffh355's Avatar
jeffh355
Default Re: FINALLY finished my Nitrous install: links (Purevil)
Thank you! I just got off the phone with NX. They reviewed this post and my pix and agree with you. Ultimately a 45 degree angle to the rear would be best, but your way with my clearence issues will work better than what I've done. This can also be done with a minimum of trouble. I just like the fact it all fits under my trunk cover. Because the bottle sits at an angle, the bottle opener just touches the cover now.
Old Feb 8, 2003 | 07:44 PM
jeffh355's Avatar
jeffh355
For those of you e-mailing me: The mounts on the shroud that hold the solenoids and bottle brackets were custom made by a friend of mine out of a solid block of aluminum. As I accidentaly deleted your e-mails, please get back to me and I will forward your requests.
To FINALLY finished my Nitrous install: links
