HELP!! Knock in the Rear....
I've had it looked at several times for this in the last couple of months. They replaced the shock (though I told them it probably wasn't that) - but just to rule it out. The car was right back in with the same sound. They replaced the bushing and the rear control arm.
The car has sat for about two weeks (it's darn cold up here) and I took it out today and the noise is back with a vengence. Is this just a "cold knock" kind of thing b/c it has sat for a bit in freezing cold weather? Or is it back to the dealership? Anyone had to deal with this? :mad
Thanks for the input :grouphug:
Your profile didn't list if you have a stock exhaust or not. The stock exhaust system on the 2000s did have a problem with broken welds at the flanges located in front of the rear axle.
The rear sway bars are prone to a lot of weird noise. You can clean the sway bar where it contacts the bushings, lube the bushings with waterproof lithium and check the rubber bushings themselves for damage.
The rear hatch bumpers may be making noise. Try a little silicone on the tips. Also your rear hatch may be rattling, so check for the proper clearance after closing.
