tire valve stem torque, how much?
Old Nov 18, 2024 | 07:28 PM
Alley Oop's Avatar
Alley Oop
Default tire valve stem torque, how much?
Got this from the internet: If the valve stem is loose, the assembly leaks. If it is too tight, corrosion will begin to form around the valve stem and a leak will soon follow. The recommended torque for standard aluminum wheel valve stems is 7 to 11 ft/lbs or 80 to 125 in/lbs
That seems like too much torque for a tire valve stem. What do you recommend?
Thanks in advance.
Old Nov 19, 2024 | 06:43 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
I does not sound excessive to me but I would consult the valve stem OEM's installation instructions if I were you.
Old Nov 19, 2024 | 08:23 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
2001 Factory Shop Manual, 35 inch pounds........
Old Nov 19, 2024 | 06:24 PM
Alley Oop's Avatar
Alley Oop
Thanks guys.
To tire valve stem torque, how much?
