PCM Removal
Old Feb 7, 2003 | 03:02 PM
SENNA forever's Avatar
SENNA forever
Default PCM Removal
Need to remove my PCM for Programming .Some help would be appreciated.
Where do I find the PCM...by the drivers or passenger front wheel ?
Any further information I should know is appreciated.
Thanks.
Manuel.
Old Feb 7, 2003 | 03:05 PM
Patches's Avatar
Patches
Default Re: PCM Removal (SENNA forever)
Just behind the front passenger wheel. Remove the wheel well cover and the cove cover inside that and you'll see it with the throttle module attached to it. Kinda' a PITA to reach the rear screw but doable. Be careful undoing and reconnecting the harnesses.
[Modified by Patches, 3:07 PM 2/7/2003]
Old Feb 7, 2003 | 03:16 PM
SENNA forever
Default Re: PCM Removal (Patches)
Patches thank you for the info.
Do I have to remove the whell and lift the the car for easy excess or its not
necessary ?
Sorry I am a rookie at this.
Old Feb 7, 2003 | 07:00 PM
NoProblem's Avatar
NoProblem
Also you might want to give this link a shot also has photos.
Good Luck :cheers: http://frankhunt.com/FRANK/hobbies/c...s/PCM/pcm.html
Old Feb 9, 2003 | 04:58 AM
SENNA forever
Default Re: PCM Removal (NoProblem)
Got it out safetly,thank you for the help guys, your the tips made all the difference :cheers:
Manuel.
To PCM Removal
