PCM no comm, crank no start situation, help!!!
Old Nov 22, 2024 | 02:20 PM
Rhollenbeck18's Avatar
Rhollenbeck18
Default PCM no comm, crank no start situation, help!!!
1997 c5, 0411 swap, ecu purchased off of ebay. (2002 c5 z06 i believe)
Purchased the car a few years ago and have never had the time to dig further into the reason it does not run. it will crank, there is no security light, has fuel pressure, it seems as if injectors arent being given the ground through the PCM.
hate to admit it but i have put a small shot of starting fluid and it fires.
Prior to repinning electrical connections, when i bought the car i was told that the intake just needed to be put on and when the previous owner pulled the intake they lost the keys during the job, bought a new ignition and that it where we are at.
A friend of a friend said that they disabled vats possibly im not exactly sure what they did to the ECM.
looking for recommendations on what would cause a PCM no comm after a 0411 swap. ive cleaned ignition switch contacts. attempted to verify correct ohms at pins in ignition switch, wondering if i should just call a locksmith to come give me a key with the correct resistance pellet.
I am trying to check everything or reach out for help before sending it to a shop as every shop is going to be confused as to why i did the 0411 swap when it reality it was because i misplaced my stock ECM, but he car would crank and not fire the injectors with the old one also. Any and all help is greatly appreciated, ive studied post after post on this website and have tried everything with no success. cleaning ground points,
what i dont get it is why i dont have a security light on when trying to start it
Any and all help is greatly appreciated. thank you all
codes are as follows
PCM no comm
TCS c1232HC, U1255HC,
RTD no comm
BCM B2527HC 2723H u1255hc,
HVAC no vcom
ldcm u1255h, u1064h, u1016h, u1096h,
rdcm u1255h, u1064h, u1016h, u1096h
scm no comm
rfa u1000hc
Old Nov 22, 2024 | 06:49 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
For a PCM or any module “No Comm” the first thing you should check are its power and grounds…usually an ignition and battery feed and ground.
Old Nov 22, 2024 | 06:56 PM
C5 Diag's Avatar
C5 Diag
Power and Grounds spread between both connectors…and resistance checking is NOT how to check grounds !!
Old Nov 22, 2024 | 07:08 PM
C5 Diag's Avatar
C5 Diag
2 battery, 1 ignition, and 4 grounds…you load test the grounds…I’d use a headlight bulb that draws about 2 amps to check the grounds.
Old Nov 23, 2024 | 09:52 AM
lucky131969's Avatar
lucky131969
The pinout on a 1997-1998 PCM is different. Not going to work with a 2002 PCM. The pinout changed in 1999.
Old Nov 23, 2024 | 09:58 AM
Rhollenbeck18
i changed the pinout
Old Nov 23, 2024 | 10:01 AM
Rhollenbeck18
@C5 Diag I’ll double check all that, I wasn’t checking grounds with ohms, just pin continuity when changing the orientation of the key position. On, acc, start. It’s a little confusing. But I’m not convinced the it’s ignition switch I took it off and cleaned all the contacts.
Old Nov 23, 2024 | 10:05 AM
Rhollenbeck18
@C5 Diag thanks for that engine controls schematic. I’ll be poking around there and see if I come up with anything out of the ordinary
Old Nov 23, 2024 | 10:08 AM
Rhollenbeck18
@C5 Diag actually i would need the 2002 version, I can try and use the material I have to verify.
Old Nov 23, 2024 | 10:15 AM
lucky131969
Ok. Well the class 2 for the PCM would be an easy miss, because it has the same position (58) but moves to the other connector.
Good luck.
Old Nov 23, 2024 | 10:51 AM
C5 Diag's Avatar
C5 Diag
OH, it’s a 2002…thanks !!
Old Nov 23, 2024 | 10:52 AM
C5 Diag's Avatar
C5 Diag
Sorry, missed that !!
Old Nov 23, 2024 | 11:06 AM
C5 Diag's Avatar
C5 Diag
Here is wiring for a Z06…would also be a good idea to remove the splice pack “comb” from the splice pack and make sure it’s clean…pin B (dark green).
Old Nov 23, 2024 | 11:07 AM
lucky131969
Well....it's a 1997 C5 with a 2002 PCM
Old Nov 23, 2024 | 11:08 AM
C5 Diag's Avatar
C5 Diag
Got it !!
Old Nov 25, 2024 | 09:54 AM
Rhollenbeck18
Well cant believe it but I found it, the dang class 2 pin was on the wrong side of wire 57 SMH, thank you so much @C5 Diag and @lucky131969 I really appreciate the help. i feel like i havent made any progress with this car up until this point.
It was on pin 56 not 58. where it should have been hoping I dont have any more like this.
so now all i have is the theft deterrant code 1631 and 1626 should i just call a locksmith or should i try to relearn the theft learn procedure in order for the system to learn the new password. after research on the site i see the PCM and BCM passwords dont match.
Old Nov 25, 2024 | 10:18 AM
lucky131969
Progress !
So let's review. The PO lost the keys, and you purchased a new ignition with new keys? Which key code did you get?
To PCM no comm, crank no start situation, help!!!
Old Nov 25, 2024 | 10:37 AM
mmartinez's Avatar
mmartinez
The only way you could have purchased the correct key was to go to a dealership and give them the cars VIN. A previous owner may also have changed the Ignition switch and used a different key other then the cars orginal key. You will have to perform a BCM relearn procedure.
Old Nov 25, 2024 | 11:18 AM
Rhollenbeck18
@lucky131969 PO lost keys and I believe purchased new keys and switch. So I’m not sure what code he got.
@mmartinez i was going to do that years ago but I never got the change to get to the dealership with the title in my name to find out what resistance I’m needing. I’m trying to do the relearn process at the moment but I tried and had no luck. Actually oops I hope my connector is plugged in for the resistance of the key eek. I’ll go back down verify. But I did the 11 minute on 30 secs off, three times, ordeal and didn’t have any luck.
Old Nov 25, 2024 | 12:05 PM
mmartinez's Avatar
mmartinez
If you did the relearn procedure with the connector unplugged it won't work. Also put a charger on the battery during the relearn, if battery voltage drops to low the relearn will fail. Hope this helps.
